Recommendation for wiring amp/subs...
Old May 20, 2010 | 10:40 PM
freekyFX4's Avatar
I have two 12" L7's in a sealed enclosure. The box has 1.3 cu ft per side. The amp is a Soundstream Picasso 2000D. Supposedly it puts out:
2000 watts at 1 ohm
1500 watts at 2 ohms
1100 watts at 4 ohms
Here is the problem...my L7's are the dual 4 ohm voice coil variety, which means that I can run 4 ohms or 1 ohm load across all four voice coils. The speakers can handle 750 watts RMS each. Optimally, it would be best to run the amp at 2 ohms, but that is not an option. So, would I be better off running the amp at 4 ohms or 1 ohm? How will this affect the output? This box is only going to be used to supplement the "high end" 300-watt audio system in my son's 2006 GTI, so it really doesn't need to be that loud and will probably keep the gain turned down quite a bit anyway.
Thanks for any info.
Old May 21, 2010 | 08:36 AM
PorkCereal's Avatar
If it will handle 1ohm w/o over heating id do that. More power available is always better.
On the safer side, 4ohm will give less power but cause less stress on the amp.
Old May 22, 2010 | 05:44 AM
freekyFX4's Avatar
Thanks. I went ahead and wired the voice coils in parallel so each sub is 2 ohms. That way, we can try 4 ohms and 1 ohm without having to take out the speakers.
Old May 22, 2010 | 03:35 PM
Ray21's Avatar
I would wire them up at 1 ohm and just set the gain conservatively.
Old May 22, 2010 | 07:22 PM
JJDH's Avatar
That is a good amp. It will be fine at 1 ohm.
Old May 25, 2010 | 05:46 PM
Jwool15's Avatar
yea I ran my sundown sae1200 @.5ohms and never had a single problem. Then pushed it to 1ohms and its still set there today no problems whatsoever. They do make a very solid product you got nothing to worry about. I say set at 1ohm and set gain conservatively so when he wants to be really loud he could turn the gain up a bit and show off. L7's can handle way more than 750 each they'll eat up whatever you throw at them. My L7 15 saw a little over 3000@1ohm on a daily basis and if you know me you know I listen to it loud and I beat the **** out of that thing and never had a problem wit it. It actually didn't sound too bad I had it in a sealed box so it wasn't very sloppy at all and sounded really good for a pure spl sub and damn did it get loud!
