05 Audiophile sub in a 2010?
Old May 8, 2010 | 11:29 AM
torque_monster's Avatar
I have an audiophile sub out of my 2005 Lariat and would like to put it in my 2010 XLT how can i tap in the wires?
Before all you guys go telling my to go aftermarket, save your breath, I just want to use what I have and have a small clean looking sub.
Thanks for the help.
Old May 8, 2010 | 09:44 PM
PorkCereal's Avatar
If you dont have the plug back there id run an amp kit. 40$ now will save you lots of trouble when you go to replace it.
Old May 8, 2010 | 10:26 PM
Tell me more on this "amp" kit, where can i get one?
Old May 16, 2010 | 07:55 PM
Anybody??
Old May 17, 2010 | 09:18 AM
PorkCereal's Avatar
http://lmgtfy.com/?q=CAR+AMP+KIT
Old May 17, 2010 | 01:02 PM
GATORB8's Avatar
It's more involved than you are thinking. The audiophile subs in the 04-08 recieved a low pass crossedover signal from the head unit and a 5 volt turn on.
So you'll need a Line Output Converter and a Crossover (you may be able to find a combo) an amp kit (you'll be drawing less than 20 amps so 8-10 gauge is should be adequate check out knukonceptz.com)
If you get a LOC with a turn on lead, you'll need to run a voltage divider to supply the 5V turn on for the stock amp.
