10 sub, 2 Ohms or 4 Ohm?
Old Mar 17, 2010 | 06:38 PM
Bouffi's Avatar
Folks,
Thanks again for all your help in this forum, ton's of good info. I have an Alpine Amp (PDX 4 150) that I'm bridging for a sub. I'd like to get just 1 10's sub in an e-bay box under the back seat of my 05 Screw.
The issue I'm having with this game plan is that there's 2 model of the Alpine SWS 10 " subs, one for 2 ohms and the other for a 4 ohms setting. Both are dual coils.
My question, which one works?
Thank you very much for your help with this.
E.
Old Mar 17, 2010 | 07:02 PM
anix11's Avatar
they will both work. you could wire the 2ohm in series if you wanted to play it at 4 ohms, or wire the 4 ohm in parallel to get 2 ohms.
and with the PDX amplifiers they push they same power at 4 ohm and 2 ohm.
on alpines website it says "bridged 4 ohms : 300Wrms X 2" so you could just get the dual 4 ohm and bridge it at the amp
Old Mar 18, 2010 | 09:05 AM
PorkCereal's Avatar
http://www.the12volt.com/caraudio/wo...igurations.asp
Use this to determine your final load. Match it to what works best with your amp.
As a general rule its easier to find higher power amps that push 2 ohms then 4.
But after rereading your bridging a 4 channel to a sub, not a great idea. You have to run a dual 4 ohm sub and bridge each channel to a single 4ohm voice coil. Which means you are going to give each coil 200-300w(300w@14v) on a 300w RMS sub (150w on each coil). Thats slightly over powered so becareful with your gains.
Old Mar 18, 2010 | 07:58 PM
Bouffi's Avatar
Well, my game plan was to use 2 channels to power the front components and bridge the other two to power the sub. I can set the amp in bridge mode to 4 ohms, I'm guessing I'll need a 4 ohm subs then (2 coil)/ Alpine S?
Old Mar 19, 2010 | 08:46 AM
PorkCereal's Avatar
Still wouldnt recommend it. Not sure if that amp is going to like 2 channels bridged and 2 not.
You would have to run a dual 2ohm and wire it to a total 4 ohm load.
http://www.the12volt.com/caraudio/wo...s.asp?Q=1&I=22
Old Mar 19, 2010 | 11:36 AM
Bouffi's Avatar
Ok, so I'm better off not powering the Amp with the 4 channel sub and get a mono to power the sub alone? I rarely use the back seats so I didn't feel the need for powered (except from the HU) speakers in the back.
