Is this right??
Old Mar 10, 2010 | 09:13 AM
Redeye's Avatar
Question Is this right??
I have on '08 Lariat Screw with the Audiophile system. I recently replaced the door handles and noticed something peculiar. The main speaker(midrange, I assume) in the drivers door has two sets of wire connections. I suspect that one is to drive the midrange and the other is to drive the tweeter. On the passengers door the midrange has only one connection and the connector to the tweeter is hanging loose. Am I way off base here or is something not right?? What's driving the tweeter on the passenger's side?
Old Mar 10, 2010 | 09:31 AM
05RedFX4's Avatar
Mine looked like this
If your passenger door speaker does not have both plugs on the midrange, it would be my guess the wrong speaker was installed from the factory.
Old Mar 10, 2010 | 09:40 AM
Redeye's Avatar
Thanks 05Red! That's exactly what my driver's door setup looks like, however the passenger's door midrange is missing the bottom connector. Do you suppose this would be covered under warranty?
Old Mar 10, 2010 | 04:42 PM
PorkCereal's Avatar
Maybe if the dont notice you changed handles. They might try to charge you.
