1 Kicker Comp CVT 10 vs 2 Planet Audio RX 10s
Old Mar 5, 2010 | 11:13 AM
streetassasin's Avatar
1 Kicker Comp CVT 12 vs 2 Planet Audio RX 10s
Looking for opinions on the kicker vs the planets audios, Im more concerned with SPL instead of SQ. I have never ran PA but in my old camaro I had 2 kicker cvr 12's on a kicker kx1200.1 and loved it
*****EDIT Kicker 12" not 10"
Old Mar 5, 2010 | 12:01 PM
abervintageman4's Avatar
specs on each sub?
Old Mar 5, 2010 | 12:10 PM
kicker
Model CVT12
Size (IN.,CM) 12, 30
Impedance (OHMS) 2 or 4
Max Rec Amplifier Power (WATTS PEAK/RMS)* 800/400
Frequency Response (Hz) 25-350
Mounting Depth (IN.,CM) 4-3/8, 11.1
Mounting Cutout (IN.,CM) 11, 28.1
Min Rec Sealed Box Volume (CU. FT., Liters) 1.0, 28.3
Max Rec Sealed Box Volume (CU. FT., Liters) 4.6, 130
Min Rec Vented Box Volume (CU. Ft., Liters)** 1.75, 49.6
Max Rec Vented Box Volume (CU. Ft., Liters)** 2.25, 63.7
planet audio
Power Handling (Peak) 300W
Power Handling (Contin.) 150W
Freq. Response 30Hz-2.5kHz
Efficiency (1 Watt/1 Meter) 90 dB
Impedance 4 Ohm
Magnet Structure 40 Oz
Mounting Depth 4-3/8”
Voice Coil Former 2”
Old Mar 5, 2010 | 12:29 PM
JJDH's Avatar
He meant the output specs. Q,sd,vas,re,,xmax,bl, so on so forth...
Old Mar 5, 2010 | 01:30 PM
Sundevil2188's Avatar
I dont think its really necessary...your comparing a 400w rms sub with a 150w rms sub, and the OP is looking for SPL instead of SQ? Pretty obvious choice i think.
Old Mar 5, 2010 | 02:58 PM
millertime4060's Avatar
it mite be a tought call.. with 2 10 inch subs you get 20 inchs of cone area.. which will be more sound.. but with the 12 you will have over double the watts. mite be real close..
Old Mar 5, 2010 | 04:25 PM
JJDH's Avatar
Port the 12. Feed it alot of juice.
Old Mar 5, 2010 | 07:49 PM
mSaLL150's Avatar
More cone area doesn't necessarily mean more sound. And more power doesn't necessarily mean more sound either...
2 10s will give you 157 sq inches of cone area. 1 12 will give you 113 sq inches of cone area. However, those 10s are very excursion limited so the 12 will likely displace similar amount of air as those 2 particular 10s combined. The 12 will also play lower frequencies with authority in the proper enclosure.
But IMO, I'd go with neither of those options for SPL. Actually I would do neither for SQ either.
Old Mar 5, 2010 | 07:54 PM
JJDH's Avatar
LOL.. I was trying to be nice....
