JL Audio Clean Sweep
Old Jan 28, 2010 | 08:55 PM
BigBlue00's Avatar
So today I got my hands on a JL Clean Sweep. Just wondering if anyone has used this and would recommend using it. Not 100% sure on what it does, it was free and figured I'd take it just in case it might be worth installing.
-TJ
Old Jan 28, 2010 | 11:52 PM
deton8r's Avatar
I considered buying one but ended up getting Maxxsonics MX-1. If you want to take advantages of the setup features of the JL, you should also check out the RF 3Sixty.2.
If your planning on getting an aftermarket head unit, you won't need any of these.
Old Jan 29, 2010 | 12:44 AM
Sundevil2188's Avatar
Why wouldnt you use a cleansweep or a 3sixty.2 with an aftermarket headunit? Both usually offer better eq settings along with higher voltage preouts then the vast majority of aftermarket decks.
Old Jan 30, 2010 | 12:24 AM
BigBlue00's Avatar
I mean considering it was free I will play around with it and see what I can do with it. Shouldn't be to hard to install.
