Sub wiring questions?
Old Jan 27, 2010 | 04:41 PM
marcus1033's Avatar
OK, I will be installing the new BM which is a DVC 4ohm single speaker on a single channel zapco 500.1 mono amp, so the amp will see 2ohm's. Is it possible to install 2 BM DVC 4ohm speaker's and have the amp still see 2ohm's. How would I accomplish this?
Do you think the amp would be to small for to BM's?
Old Jan 27, 2010 | 05:25 PM
PHGFX4's Avatar
http://www.the12volt.com/caraudio/wo...igurations.asp
Old Jan 27, 2010 | 11:07 PM
Sundevil2188's Avatar
No, you cant make two subs wired down to 2 ohms. Your options are 4 ohms or 1 ohm.
And yes, that amp would be underpowering two of those subs.
Old Jan 28, 2010 | 11:44 AM
marcus1033's Avatar
Yep that's what I thought. Two would have probably been more than I wanted anyway. My mach 1 had two bazooka tubes and I was more than happy, so I would think one BM should exceed my expectations.
