Anyone with Componants(97-03)
Old Dec 9, 2009 | 02:31 AM
Stephen87's Avatar
how did you install them
I got some 6"(6.5" if I include the mounting surface) component speakers and I was wandering how some of you installed yours
they are db drive speed series(round ones)
Old Dec 14, 2009 | 10:16 PM
jump n's Avatar
Sorry there hadn't been any replies to you yet. Unfortunately, I don't have pics available of mine, but I have Infinity components. Removed the factory speaker, traced it onto 1/2" mdf, cut out mounting hole for 6". Drilled holes in mdf for sheet metal screws to mount to door. Wired woofer and tweeter. Mounted tweeter behind grill area of the factory door panel. Mounted crossovers low inside door to keep out of window operations. That's my basic how-to. I plan on doing some sound deadening this spring, I'll try to take pics then. It may look a little ghetto, but works for me!
Old Dec 15, 2009 | 02:38 AM
Stephen87's Avatar
anything that can get me going in the right direction
Old Dec 15, 2009 | 10:39 AM
russ10screw's Avatar
I have a pair of the Polk 6.5" components in my doors. My first pair (installed by someone else) I had everything behind the factory grill and the crossovers mounted on the kickpanel under the dash (couldn't see them). Last Christmas I installed a new pair of Polk 6.5" components. You can see pictures of the install in my gallery "Stereo Install". Not sure if you want to take that risk, but I cut out tweeter holes near the door handle. I installed the mid on a 1/2" mdf that covered the factory location. I also have sound deadening on the doors. I ran new wiring prior to installing the speakers. I mounted the crossovers on the back wall next to my amps on an mdf board. Let me know if you have any other questions. Hope this helps.
Old Dec 15, 2009 | 11:05 PM
Sundevil2188's Avatar
What did you use to cut through that leather with?
Old Dec 16, 2009 | 12:31 AM
Well, I was scared to death to do that, so I somewhat cheated. I had gone to a junkyard to find a new door panel for the passenger side because some of my clips on the back had broken off from pulling the panel off and on too often (my first install wasn't all that great and I had to keep going back in and retighten the mounting screws). So I had a practice panel to work with. But to answer your question, I used one of those hole bits (have a real drill bit in the center but then a ring with jagged teeth that makes the hole). I used the size that was one size smaller than the tweeter mount. Then I used a dremel to file the plastic part thats behind the leather. Once I got it big enough for the tweeter mount to pop in, I was good to go. Using the smaller size hole cutter, kept me from having to worry about frayed edges on the leather. They just tuck in nicely behind the lip of the mount. Hope that helped!
Old Dec 16, 2009 | 01:33 AM
Stephen87's Avatar
I am probably going to mount my tweater on the sail thingy
Old Dec 16, 2009 | 01:53 AM
That would probably work as well. I was just trying to minimize the distance between the tweeter and the mid-range while still keeping them "separate".
Old Dec 16, 2009 | 02:15 AM
Stephen87's Avatar
oh ok that makes sense
Old Dec 16, 2009 | 03:28 PM
hmmm okay. thanks for the advise. I was racking my brain figuring out how to cut it without leaving marks.
My tweets were too big to fit up there...make sure you measure first.
Old Dec 16, 2009 | 08:32 PM
Stephen87's Avatar
I am going to need to do that cause I never thought that they might be to big
Old Dec 16, 2009 | 11:41 PM
My only advice would be to make sure you have your drill fully charged and high speed. Also make sure the entire bit is nice and tight. I learned that the hard way on my passenger door. The bit wasn't tight and when I went to go through the leather it yanked it and tweaked it a bit. Fortunately, as I mentioned, I used the smaller size just in case I had to cover up any rough edges.
And now that you mention it, I think I did run into a bit of that problem in the sails as well. I don't think they were quite big enough.
