5-10s & 2-12s Behind My Head
Old Dec 7, 2009 | 08:42 PM
  #76
abervintageman4's Avatar
Originally Posted by JJDH
surface, sd, xmax, efficiency..
what about fs, the material of the voice coils, the size of the motor?
Old Dec 7, 2009 | 08:45 PM
  #77
coobies5's Avatar
bull****.....jl w7 cheapest i've seen brand new from dealers = well over $800
all the other woofers abervintageman just said from the actual manufacturers themselves are wayyyyyy less then the jl's brand new. about the most expensive sub he listed was the fi btl and for one fully loaded shipped to your door is only $469
Old Dec 7, 2009 | 08:49 PM
  #78
coobies5's Avatar
jl w7 13.5"
Free Air Resonance (Fs): 23.5 Hz
Electrical “Q” (Qes): 0.476
Mechanical “Q” (Qms): 7.517
Total Speaker “Q” (Qts): 0.448
Equivalent Compliance (Vas): 3.68 cu. ft. / 104.3 liters
One-Way, Linear Excursion (Xmax)*: 1.25 in. / 32 mm
Reference Efficiency (no): 0.269%
Efficiency (1W/1m)**: 86.3 dB SPL
Effective Piston Area (Sd): 107.35 sq. in. / 0.0693 sq. m
DC Resistance (Re): 2.41 ohm***
Nominal Impedance (Znom): Dual 1.5 ohm
Thermal Power Handling (Pt): 1500W
Driver Displacement: 0.21 cu. ft. / 5.9 liters
Net Weight: 52 lbs. / 23.6 kg
fi btl 18"
Fs: 31.9 Hz
Re: 0.7 Ohms/coil
Qes: .26
Qts: .24
Mms: 313g
Sd: 1210cm^2
Vas: 163.1 l
Spl: 94.9dB 1W/1m
Bl: 18.3 N/A
Xmax: 28mm
Rms: 2000W
Ported box: 5-10cuft
Sub OD: 18.500”
Cut ID: 16.750”
Mounting depth: 10.250”
Displacement: 0.26cuft
Old Dec 7, 2009 | 08:52 PM
  #79
coobies5's Avatar
laggy server
Last edited by coobies5; Dec 7, 2009 at 08:52 PM. Reason: double post (site being slow)
Old Dec 7, 2009 | 08:53 PM
  #80
JJDH's Avatar
it will take days to figure this out. of course there are better...no ****.... for less money is all that needs to be answered... lets get it..
Old Dec 7, 2009 | 08:57 PM
  #81
JJDH's Avatar
the w7 from jl is over 800.. ....and yes this server is too slow for this shiat. there are so many variables each is better in their own way than the other. i was trying to stir the pot anyway, this could get very involved... oh coobies whats with the hillary dufff... there is better u know...
Old Dec 7, 2009 | 09:02 PM
  #82
coobies5's Avatar
audioque HDC318 $309 each
SoundSplinter RL-s 12" $450
18" SSA XCON $399
incriminator 18" Death Row Series $379
18" Death Penalty $509 get a 21" for $599
just wait, once the aa smd's are out sure they will be a pretty penny, but it will just blow away the competition.
Old Dec 7, 2009 | 09:03 PM
  #83
coobies5's Avatar
hillary duff? what?
  #84
JJDH's Avatar
in ur sig.........also u cant compare an 18" to a 12" for specs....
Old Dec 7, 2009 | 09:05 PM
  #85
coobies5's Avatar
am i blind???
i dont see anything relating to hillary duff at all?
Old Dec 7, 2009 | 09:07 PM
  #86
JJDH's Avatar
Originally Posted by coobies5
am i blind???
ok than who is that chick???? i must be blind then
Old Dec 7, 2009 | 09:11 PM
  #87
coobies5's Avatar
rachel bilson?
and on the 12" to 18" specs, the smaller the woofer the cheaper.....specs vary only a little too.
  #88
coobies5's Avatar
strike two for f150o
Last edited by coobies5; Dec 7, 2009 at 09:15 PM. Reason: one more and you're out!
Old Dec 7, 2009 | 09:18 PM
  #89
JJDH's Avatar
rachel bilson......ok.eveytime i see ur sig i thought that was duff... do you have pics of your install???
Old Dec 7, 2009 | 09:24 PM
  #90
coobies5's Avatar
lol, its nothing special, no back seat, a 3/4" mdf box roughly 6 cube internal volume side firing port, not covered in anything but screws and woodglue and silicone, amp is under my seat.
but, i will be building a new box and covering it with some sort of fabric that is easy to come by, and i'll be building a center console to house the amp and a battery or two.
