speaker question
Old Nov 30, 2009 | 03:04 PM
mav015's Avatar
speaker question
ok so i have the avic700bt want to get new speakers.
should i run the off the head unit alone or should i get an amp, i want the system to sound good
i was thinkin about the pioneer TS-A702C or the infinity REF6830CS, what do yall think?
if i should get an amp what should i be looking for?
open to any opinions or ideas
thanks yall
Old Nov 30, 2009 | 05:37 PM
PorkCereal's Avatar
Sound systems all depend on how much you want to spend. Will new speakers sound better then stocks, mostly yes. If you get the correct ones that dont require a lot of power.
Give us a dollar amount.
Do you plan on running a sub also?
Old Nov 30, 2009 | 07:24 PM
mav015's Avatar
well i figure like 800 to a grand for the 4 speakers and amp
i have a sub already kicker solo classic with a 1500 watt amp so im just lookin to get speaker to match it. The bass kinda of powers the stock speakers
wat do yall think
thanks yall
Old Nov 30, 2009 | 08:06 PM
PorkCereal's Avatar
Well what i believe most of the SQ guys recommend is doing a good set of 6.5 componets in the front then leaving the back out/off or just running something 5x7 ran to the headunit. You have a high $$ amount so shoudnt be hard. You can probably achieve what you want for closer to 4-500 if you do the work yourself.
Old Nov 30, 2009 | 08:21 PM
mav015's Avatar
yea i was goin to do it myself i did the sub myself much cheaper that way im just seein wat the opinion is as to the best compenents
and an amp to makem sound good
thanks yall
Old Dec 1, 2009 | 12:09 PM
mav015's Avatar
what do yall think about these speakers MB Quart PVI 268??
found em for 130 buck a set
thanks for the info
Old Dec 1, 2009 | 12:15 PM
PorkCereal's Avatar
That is beyond my knowledge. I have been out of the game for years and often relied on others opinions of speakers. I myself are trying to research to find a decent set of 6.5 componets. Im in the middle of reading about different sound deadners and about halfway through.
msal and a few others seem to know there stuff and have played with alot, hopefully they will chime in or send em a PM. He normally replies back to me fairly quick with good info.
Old Dec 1, 2009 | 12:23 PM
mav015's Avatar
thanks man
