2 or 4 ohm
Old Nov 3, 2009 | 03:41 PM
sloenuf's Avatar
2 or 4 ohm
looking for a sub to replace my old one. whats better a 2ohm or 4ohm sub. new to this. itll be powered by a 600watt 2channel kenwood amp thats bridged down to one channel. just curious which is better
Old Nov 3, 2009 | 04:04 PM
sloenuf's Avatar
http://www.crutchfield.com/S-NqkGiKH...C-829.html?s=0 this is the amp
Old Nov 3, 2009 | 05:50 PM
Impact9's Avatar
it's all relative to your situation. Are you only one sub? If you are then get a 4 ohm because I don't believe that amp will run 2 ohms bridged.
Old Nov 3, 2009 | 07:41 PM
sloenuf's Avatar
yes only one sub
Old Nov 4, 2009 | 09:10 AM
fozzy's Avatar
In your case go with a single 4 ohm. I have had and still have older amps of this line the KAC PS-150 and they are still working today. I have used them to run single subs, component sets, and even in tri-mode. Only ever had to get them worked on after one of my older cars was rear-ended and totalled. It caved my trunk in 13 inches. I took them in for repair just to be on the safe side. I don't know of any amp on the market that can take that kind of impact.
Old Nov 4, 2009 | 11:02 PM
sloenuf's Avatar
yea i had it hooked up to a older jbl lc1250 4ohm. got greedy and blew it the other day
