i dont know what im doin
Old Oct 31, 2009 | 08:33 AM
krazyballer's Avatar
Impact9-i forget what website i saw that on
Sundevil2188- the amps been working for me and im not in for competion or anything close so i don't mind
akmrue-whys that?
Old Nov 2, 2009 | 11:43 AM
akmrue's Avatar
My understanding of Ohms is as follows:
When electricity is passes into the speaker, some of it is resisted. The ohms rating of the speaker is a measure of how much electricity is resisted by the speaker, and an indication of how much energy it takes to drive it. The higher the ohms rating, the more difficult it is to drive.
When an amp manufacture gives it's wattage rating, it's always at a specific Ohm resistance. "100 watts @ 4 ohms," for example. When the resistance is 4 ohms, this amp will produce 100 watts. If that resistance changes, the amp will produce a different amount of watts.
IE: 100 watts @ 4 ohms it may produce 300 watts @ 2 ohms. Which would make your speaker hit harder. Someone please correct me if I am wrong.
Hope this helps.
Old Nov 2, 2009 | 08:37 PM
mSaLL150's Avatar
Originally Posted by akmrue
The sub is rated for 4ohms... I would get a sub rated for 2ohms.
Run a 2 ohm load to a bridged 2 channel and enjoy the fireworks. NEVER do that.
Hope this helps.
While part of your post is definitely correct, you are missing a couple important details. While the amplifier can put out more power at a lower resistance, it also becomes less controlled at lower resistance. What this means is the sound quality is reduced at lower resistances, and the amplifier creates a ton more heat while drawing more current. Running extremely low resistances to get more power can get dangerous quickly and can easily damage equipment if not done right.
You need to check the lowest stable resistance rating of your amplifier before trying to run a lower resistance load. Most 2 channel amplifiers that are stable to 2 ohm in stereo mode are NOT stable at 2 ohm when bridged, which is why running a 2 ohm sub to that Sony amp with bridged channels is a pretty poor idea.
Also, some amplifiers have regulated power supplies so they can produce similar power at different resistances. The JL Audio HD series is a good example of this.
Not trying to argue here, just trying to help clear things up a bit.
Old Nov 2, 2009 | 10:05 PM
akmrue's Avatar
Thanks for adding your input! I was just trying to stir up some ideas to help this guy out.
Old Nov 3, 2009 | 05:42 AM
thanks guys
Old Nov 3, 2009 | 10:52 AM
akmrue's Avatar
Hope that helps. Just trying to get you where you want to be.
