Sub Box Install issues - Need Help
Old Oct 15, 2009 | 09:41 PM
F150Kid316's Avatar
Alright everyone, Ill break down the situation for you and see what you bass heads out there can help me with.
I have a 02 SupCab, Split Bench Rear Seat, Jack Under Seat ( Pass Side ).
I bought a SuperCrewSound dual 10" Sub Box, I have the box and amp installed where they should be.
The Question I ask is this - how the hell do you get the damn screws that hold the jack in place out so I can slide the box all the way back?
The long one, is the culprit. It doesnt twist out and I can hammer it out....I guess im issing something. Ive searched the forums and web for any info....hell i even consulted chiltons and they dont say a thing about it.
Lemme know what yall think!
Old Oct 15, 2009 | 11:05 PM
datdude68's Avatar
I have an 2006 supercab just lossen the jack and slide it of the housing. The housing will still be in the way though 2 bolts secure it to the floor. Just unbolt it and screw the bolts back in to the floor after you remove the housing.
Old Oct 16, 2009 | 11:20 AM
F150Kid316's Avatar
I Tried that and it doesnt seem to want to move, it twists a little bit and stops, ive put a pair of channel locks on the **** for it under the truck and tried to twist there, still no luck.
Am i missing a locking collar somewhere or something?
Old Oct 16, 2009 | 04:53 PM
datdude68's Avatar
So the jack is out and you just have the base there?
Old Oct 16, 2009 | 04:56 PM
thejake1989's Avatar
datdude- the process will be different for the 02 than your model truck. ford changes things up so often things in my 98 are different from an 03 etc.
what your saying is you have the jack out and there is a mounting bolt you want out also?
can you get a pic of it
Old Oct 17, 2009 | 02:54 PM
F150Kid316's Avatar
ok, thanks to all your Q's and A's
All i have left to remove is the long bolt the holds the jack and box in place under the seat.
essentially its the screw that the black "wingnuts" attach to.
Thansk again
