Problem's F150 Sub's
Old Sep 2, 2009 | 01:22 PM
ProblemHouston's Avatar
Well, I finally have the time here at work to post the sub build in my 2006 Ford F-150 Supercrew. I had a lot of old school stuff laying around including the 3 JL 8w6s. So I figured I could fiberglass an enclosure under the rear seat of the truck to get a little bit of bass in there. Here goes:
Got everything taped and and prepped for glassing.
Got som foil down and built the frame fit in place.
After I got the bottom sealed up and the rings in place my girfriend and I filled it with sand and got right at 1.10 cubic feet.
Old Sep 2, 2009 | 01:23 PM
I stretched the fabric and put the upper rings in place to hold the shape.
Soaked the fabric in resin.
I added 3 layers of fiberglass to the cloth to make sure it was strong.
Here, Bondo has been applied and sanded to get it smooth enough to cover. I also test fit the subs.
Old Sep 2, 2009 | 01:24 PM
Finally got the carpet on.
Here is the final product installed in the tuck with the seat down and the seat up.
The 3 subs share the 1.10 cubic feet and it is also stuffed with about 1 and a quarter pounds of polyfil. The subs are wired to a 4ohm load as I didn’t know which amp I was going to power them with. Currently I am running a mono MB Quart amp that is supposed to be producing 600 x 1 at 4 ohms. After messing with the deck and realizing that at the beginning I was using both the sub x-over in the head and the amp I decided to defeat the one in the head and use the one on the amp. I am having a hard time blending the subs in with the fronts. The front consists of only a 5 1/4 Focal polyglass comps and there is no mid-bass coming from them at all. Once I go active up front with my H-700 and my Dyn 6 and tweet I should be better able to get them to play together. To my surprise the sub setup gets pretty low and does a great job down there sound wise. If I can get enough out the the 6's in the doors I should be able to use the subs for just the really deep stuff where it is really at it’s best thus far.
Old Sep 2, 2009 | 10:18 PM
Sundevil2188's Avatar
Thats really clean looking man. Nice work...I wish I knew how to fiberglass.
Old Sep 2, 2009 | 10:49 PM
jdruzik's Avatar
Great job... Looks outstanding... How does it sound?
Old Sep 3, 2009 | 12:07 AM
IH8ATTN's Avatar
umm is there room for those subs to breathe?
Old Sep 3, 2009 | 11:23 AM
The subs themselves sound pretty good without any EQ. Like I said, I am having a tough time blending them with a pair of 5 1/4 components but when I get the doors done and new 6's in there I should solve that problem. I also have an Alpine H700 that I will use to get some eq on them. I was very surprised how low they play. They can get the truck to shake a bit on the inside without you being able to tell outside the truck with the doors closed and windows up.
Old Sep 3, 2009 | 11:27 AM
Yup. JL says that each sub needs .33 cubic feet sealed and I have a total of about 1.10 cubic feet total. On top of that I have the enclosure stuffed with about 1 and 1/4 pounds of polyfil. They have a vented pole piece that needs at least about an inch of space behind the sub and the only sub that I had an issue with was the center sub as it sits on the hump. However I did place the sub on a 1 inch thick piece of MDF to get the right hight and everything worked out well. By using fiberglass I was able to cut down on the thickness of the bottom of the enclosure by just enough.
Old Sep 3, 2009 | 11:29 AM
Thanks. You should give it a shot. After you have done a few it gets easier. I can't tell you how many enclosures I have built only to start all over cause of something small but it was a lesson learned.
Old Sep 3, 2009 | 12:42 PM
Red02FX4's Avatar
Very nice job!! An enclosure like that would cost several hundred bucks to buy... without subs
Old Sep 3, 2009 | 01:44 PM
Thanks.
The funny thing about it all now is that I am thinking about doing a new enclosure in the middle seat under the armrest. We will see what I can come up with.
Old Sep 3, 2009 | 02:26 PM
Red02FX4's Avatar
Wanna fit one up fer my 02 Scab? I'll pay for a good non-mass produced box! .
Old Sep 3, 2009 | 04:15 PM
I wish I had the time. I work 14 hour days and just finding the time to finish this was a task in itself. It's really not hard you just have to take your time with it.
Old Sep 3, 2009 | 04:27 PM
Red02FX4's Avatar
yeah, if we had real day jobs I drive a tour bus and hardly see home but to do laundry n bump the mrs. nice try tho, eh??
Old Sep 3, 2009 | 04:32 PM
Impact9's Avatar
Man that is really nice looking! I just wonder how much sound your loosing by having them so close to the bottom of the seat. I think that's what IH8 was talking about.
