Sub Box
Sub Box
lets see the pics of your sub box, preferably under the seat and with 10's. put the diminensions also and the amount of air sapce you have.
i have a 04 supercab and would like to put some subs under the back seat so please help me out
I have a foxbox but no subs in it yet, I figured i would buy each thing at a time, so this paycheck going to get some JL W3s for it. Here are the pics from the website. Also a seat lift is not requried for this setup, I dont know to much about car audio but there is some members that lead me in the right direction, they seem to know their stuff when it comes to car audio. The price is 150.00 to your door.
F150-210-04
THIS ENCLOSURE FITS 2004-2008 FORD SUPER CAB AND SUPER CREW TRUCKS.
2-10" SEALED DOWNFIRE
12" IS NOT AVILABLE.
INTERNAL AIR VOLUME: 1.3 TOTAL
DIVIDED: NO
SUB SIZE: 10"
HOLE SIZE: 9.125"
MOUNTING DEPTH: 6 1/8" WITH A 6 INCH DIAMETER MAGNET
CONNECTORS: 2 SCREW MOUNTED SPRING TERMINALS
FLOOR CLEARANCE: 1.5"
DOES NOT FIT THE F-250/350 TRUCKS
F150-210-04
DIVIDED: NO
SUB SIZE: 10"
HOLE SIZE: 9.125"
I dont have the amp or box in yet, talked to a couple people that installed the amp under the passenger seat, it will work only if you do not have a power controlled seat. Also see some people put them on the back wall.
You can check out supercrewsound.com too, they make a box that goes under the rear seat, its a dual 10 downfiring setup, .60 cubic ft of airspace per sub.
I have a fox box with Eclipse 10's.. bought it used off a member here.. It fits really nice, good build quality.. Sounds pretty good. I'm using a Memphis 1.1000 amp that's mounted behind the rear seat.. You don't even notice the box just looking at the truck and the amp is completely hidden.. I would recommend this box to anyone, for the price it can't be beat.
