Will 6.5" fit in front door?
I got them to install with a 1/4" plexiglass plate, I would never do it again. It took about an hour to get them positioned perfectly, to much hassle.
When or if I do it again I will use a 1" adapter this time. Just get a nice peice of treated wood to use.
The one inch plate will give the screws to hold the speaker in much more bite, plus it will make the speaker fit without cutting your door.
My local installer says the 6.5" speakers will not fit in the front doors without either cutting the door, or building a 1" deep adapter. Has anyone installed 6.5" speakers and whose adapter did you use, was it a direct bolt in.?
I cut a hole in the door as large as the whole speaker and mounted it flush with the door. If I had fit it in the existing hole with some sort of adapter, I don't think the door panel would have fit back on, and if it did the speaker cone would have hit the panel as it extended outward while playing.
Mark
'00 Lightning
'79+ Corvette
Mark
'00 Lightning
'79+ Corvette
Any other responses. It looks to me like the 6.5" is not going to work without modification. How about the 5.25", Can we assume that a simple mounting plate would work there. Are there any premade adapters. The response before said that had he used a thick wood adapter then he wouldn't have gotten on the door panel, how thick and adapter can you use. What is the distance between the factory door panel and the factory speaker?
A thick piece of mounting material would be need to make a 6.5 fit comfortably, without chopping or grinding the door.
A 5.25 would fit with a thinner plate, maybe like 1/4 inch or a little smaller.
Some places you can buy plates that will work, I prefer to just make them.
Actually, DEI makes a 6.5" speaker that will fit in the door. It has a mounting hole diameter of 5.5" and a mounting depth of 2.45". That should fit perfect. I am getting a set myself tomorrow.
1998 F150 S/C
4.6 V8
Flowmaster 40 muffler
Sony CDX-C7850 CD Player
2 12" DEI Competition subs
DEI 1100D amp
4 kicker Impulse 5x7
Legacy LA360 amp
Expy console
SOON TO COME!!
Sony XE-744 Equalizer
[This message has been edited by Sandman_A_C (edited 05-31-2001).]
1998 F150 S/C
4.6 V8
DEI 1100D amp
Legacy LA360 amp
Expy console
SOON TO COME!!
To put in the 6.5, I usually just trace the old factory 5x7 on 1/4" MDF and mark the screw holes. Cut out the 6.5 opening and the cut the 5x7 out and drill out the screw hole. I usually will paint this black so it doesn't stick out like a sore thumb thru the grill. The MDF just draws to much attention. Then mount the plate in the factory location and then screw your new 6.5 in. I have mounted anything from Alpine 6.5's to FoCal 6.5 seps in them.
5.25" will fit in the door with an adapter that you can purchase at almost any place that sells speakers.
www.f150world.com/HouScrew
Truck Specifications: 2001 Ford F150 4X4 Lariat SuperCrew (Gen.I) Amazon Green w/Harvest Gold Trim, 5.4L V-8, HD Tow Package, Bed Extender, Moon roof, Captains Chairs(front only), full leather interior as well as standard features in Lariat package.
List of current modifications so far: Stagecoach bug guard,
Billit Grill,
Westin chrome nerf bars, front windows tinted, wood grain kit, AudioVox 6.5" flipdown TV and VCP(DVD soon to come), Sony M610 flipdown head unit, Code SureStart Remote Start and Alarm system.
Waiting to be installed: Sony 10 disc changer, AudioBahn 5 1/4 component system front and rear, 3 AudioBahn 8" subs, 2 AudioBahn Amps
Future Modifications: AirForce One FIPK, Chip enhancement(don't know which one yet), spray in bed liner, bed cover, dual exhaust sytem
Billit Grill,
Just try some 5x7s. I have the JL xr series, and they sound great.....no cutting either.
1997 F150, reg cab, 2wd, v6
Eclipse 5341R cd player
Eclipse 3242 amplifier
Eclipse 2101 Eq/pre-amp
JL Audio XR 5x7s
JL Audio 12W3 subwoofer
JL Audio XR 5x7s
I'm new to the stereo section of the web board, but not to stereos. I've been doing this stuff myself for about 7 years. My MB Quart 6.5"s fit just fine in the front doors of my '00 Lariat with 1/4" plywood for a mounting plate (I was in a hurry!). I also have designed a downfire box with 2 polk db 12"s that fits under the xcab seat without sticking out at all (of course I had to raise the seat 1/2" with washers to get the 0.86 cu ft per side I needed). I hope that helps!
6.5 Do Fit F150 Doors
Houston Car Stereo just completed an install in my 2001 Lightning the Polk 6.5, which are very deep, fit perfectly with a 1/2" blade/adaptor.
This may already be SOP as the shop already had the wood brackets cut to size for my truck.
Good luck,
2001L Gato Rojo
Red 2001 Lightning
Polk MM465
Sony 404EQX
Good luck,
2001L Gato Rojo
Red 2001 Lightning
Polk MM465
Sony 404EQX
