Tweeters
Infinity's will fit with only some cutting of the plastic part of the door panel. One side required a little more work than the other due to the panels being slightly different. I didn't notice until after I'd started cutting, but it worked out ok.
As for wiring them, they often are part of a component set where the tweeters are matched to the woofers via a crossover. You connect one pair of speaker wires to the crossover and it splits it into a pair for each speaker.
Mark
'00 Lightning
'79+ Corvette
Mark
'00 Lightning
'79+ Corvette
