Replacement Speakers
Old Jan 29, 2001 | 06:20 AM
ncscrew's Avatar
Post Replacement Speakers
I'm considering replacing the factory so-called premium speakers in my SuperCrew. I have the head unit w/ casette and changer in the rear.
I'm not brave enough yet to cut into the door panels for components. Neither amps nor subs are in my future. I'll probably be buying from Crutchfield because I like getting their wiring harness and detailed instructions.
I'm considering the following.
Infinity Reference Series 5752cf
Polk EX Series II EX572a
Pioneer A Series TS-A6855
I guess I'll consider these as well.
Boston Acoustics FX8
Anyone have any experience with theses? Any comments?
[This message has been edited by ncscrew (edited 01-29-2001).]
Old Jan 29, 2001 | 01:40 PM
DECHman's Avatar
Post
I like the JL Audio XR-570 two way, there is a new componet set coming out, XR-570CS with a seperate tweeter and even better passive crossover.
Good speakers with an amp will make a big difference.
~DECHman
2001 S-Crew Lariat, 2wd, 5.4L, loaded, astro tonneau cover, bedrug, dealer installed bug gaurd, Precsion Power PC 2300 LE 300W amp, 2x JL Audio 8w3d4 subwoofers under rear seat, Clifford alarm with remote start, tilt, prox, omni sensor, window control, radio control, headlight control, back up battery siren, window tint, PIAA 9007 SuperWhite headlight bulbs with CATZ Zeta headlight enhancement transformers.. soon to have new subbox with a JL Audio 10w6 woofer.
Daily ride.. 1987 DECH Mustang 5L Hatchback with way more mods!
dechman@yahoo.com
Old Jan 29, 2001 | 05:43 PM
Tim56Ford's Avatar
Post
I just had the JL Audio 5.25 XR525-CX speakers installed yesterday with a single channel Xtant 202m AMP and it sounds great. I also had this great idea to put some low end Boston FX8 5x 7 in the back.
I recommend not upgrading the back speakers unless you are going to go ahead and get a 4 channel amp. I think I would just put some Bass Blockers on so that if you decide to crank the front up you will not get any bass distortion in the rear.
Tim
2001 SuperCrew
[This message has been edited by Tim56Ford (edited 01-30-2001).]
Old Feb 1, 2001 | 05:51 PM
FedExPilot's Avatar
Cool
NCSCREW,
You have probably done a search on the subject and found this thread for the speaker install ... should prove helpful:
https://www.f150online.com/f150board...ML/000092.html
BOL....
Fog Lights with parking lights .... how does he do it ?
https://www.f150online.com/f150board...ML/000552.html
<A HREF="http://albums.photopoint.com/j/View?u=1023393&a=8790857&p=28542295&Sequence=1" TARGET=_blank> </A> <A HREF="http://albums.photopoint.com/j/View?u=1023393&a=8790857&p=28542675&Sequence=2" TARGET=_blank> </A>
2001 F-150 Super Crew Lariat 4x4
5.4 engine; Chestnut w/ gold trim; Captain's Chairs; Ford/ Duraliner bed insert; Six disc CD changer (in center console); Fosgate FNP1614 component speakers (front); Pioneer TS-A6855 speakers (rear); 8 inch MTX sub in custom built, center console, sealed enclosure; ZAPCO AG150 amplifier; Moon roof; 98/99 Expedition center console; Bed extender; Class 3 trailer hitch
[This message has been edited by FedExPilot (edited 02-01-2001).]
Old Feb 2, 2001 | 12:40 AM
clancyb's Avatar
Post
I put in the Polks with Dynamats front & rear. It really improved the sound, even before I changed the head unit. It's an easy install too. The Crutchfield harness that I received didn't fit the Ford harness, but it was pretty obvious what went where. There are some detailed instructions floating around here somewhere on how to remove the door panels.
2001 Lariat SC 5.4 4x4 LS ORP Class III 17in wheels Captains seats
Sony ES CDX-M650 Polk EX572a(2 pr.) Dynamats
Westin nerf bar, ARE Z series cap, Yakima rack, Bedrug
Superchip
