? for captainoblivious
Old Jan 31, 2001 | 09:18 PM
007's Avatar
007
Post ? for captainoblivious
I saw the pictures of your speaker installation you posted the other day. I want to install tweeters in exactly the same location. Did you make or buy the "holders" that the tweeters are sitting in?
Thinking of Kenwood component system (KFC-P603) and Kenwood KAC-529S amp (trying to keep the cost down). Any comments/suggestions? This will be my first time installing component speakers.
Thanks!
Old Feb 1, 2001 | 11:22 AM
captainoblivious's Avatar
Post
007 - actually I was lucky. I got the Pioneer Premier components, and the tweeters cam with 2 holders, one that would have flush mounted them but would have required a larger whole to be drilled. And the angled holders, which is in the picture. It worked out much nicer because I only had to make 2 small hole, 1 for the wire and 1 for the screw to mount it. So I guess if I ever take them out I fill in the 2 holes with glue and paint over it for factory look.
Hope that helps.
Old Feb 1, 2001 | 11:29 AM
Post
Check out these tweeter install, they all did very nice jobs.
This has some very nice tweeter installs:
https://www.f150online.com/f150board...ML/000119.html
On this on check out Shooter's tweeter install, I really like this one and may try it when spring rolls around and I redo my system. :
https://www.f150online.com/f150board...ML/000116.html
black 97' x-cab 4x4, 5 speed 4.6, black westin nerf bars, pilot ground searchers, borla SS split rear exhaust, K&N genII, bosch +4 plugs, flexalite electric fan, v-tech oval side window covers, IAS shocks
premier 720, pioneer 6cd changer, 12 premier sub, premier componets, 2 soso amps
still to come: new spark plug wires, new rims and tires, maybe a supercharger eventually.
my soundomain page: http://members.cardomain.com/dontblameme
Old Feb 1, 2001 | 05:34 PM
007's Avatar
007
Post
captainoblivious,
Thanks for the info! The Kenwood description mentioned "angled mounts" and now I understand what that means.
Your tweeter install looks great (and so do the ones done by Slammed Expy and Shooter, that you referenced).
