? for those using an underseat box in SC
Old Jul 10, 2009 | 04:13 PM
ibcop's Avatar
Just wondering how much room you have from the floor to the sub. I have a "half-size" box built by Sound Off (awesome to deal with) to run a RF P3SD412 woofer. It fits fine, but seems awful close to the floor. I might add I did install the trim ring.
Thoughts? TIA!
Old Jul 10, 2009 | 04:27 PM
tk5075's Avatar
if its not hitting the floor why change it?
Old Jul 10, 2009 | 05:46 PM
ProblemHouston's Avatar
Thoughts? TIA!
Some woofers have a vent at the bottom. My 8 inch JL call for about an inch of clearence behind the sub (may be 3/4). If there is not vent then there is no problem.
Old Jul 11, 2009 | 02:26 AM
dilloncawthon's Avatar
I have a two 12's box made by supercrewsounds under mine and I have a good 2-3+ inches under it.
Old Jul 11, 2009 | 09:38 AM
ibcop's Avatar
Wow - I have no where near that amount of space - probably half of that.
I noticed you have a 06 model - maybe that's the reason.....I dunno. Thanks!
Old Jul 11, 2009 | 09:57 AM
Windsor's Avatar
I'm using the Q-logic box and I'm sure I have a good 2" off the floor due to the shape of the box and floor.
Old Jul 11, 2009 | 12:31 PM
i forgot to mention i also have a seat lift and the box was made with that in mind so that is why i have so much more space.
Old Jul 11, 2009 | 12:55 PM
ibcop's Avatar
I guess the design I have is different as the floor in the 09's is flat. I know the ProBox is the same way.
ibcop's Avatar
Gotcha. Thanks for the clarification.
Old Jul 11, 2009 | 10:21 PM
jdruzik's Avatar
Space...
I have about 2" of clearance under the custom box... Check the pictures...
