Can this be done
Old Jun 12, 2009 | 02:15 PM
pmason718's Avatar
Can this be done
I'm looking to purchase a JL Stealth box BUT and they usually come with the 10W3v3 4ohm sub. I want to swap the 10W3v3 4 ohm sub for a 10W3v3 2 ohm sub. The reason I want to do this is b/c my amp is already setup for a 2 ohm load. Can I put this 2ohm sub in a stealthbox that comes with a 4ohm. When I say can this be done I mean as far as cubic feet, airspace, etc.
Old Jun 12, 2009 | 05:01 PM
JJDH's Avatar
call jl, the sub should be exactly the same, only the motor would be diff, right?
Old Jun 12, 2009 | 05:04 PM
mSaLL150's Avatar
The only difference is the voice coil resistance.
If your amp is stable at 2 ohm it is table at 4 ohm, I wouldn't worry about swapping subs.
Old Jun 12, 2009 | 05:15 PM
JJDH's Avatar
more windings on coil?
