So when do you actually need a capacitor?
Old May 8, 2009 | 05:40 PM
topcat333's Avatar
I'm gonna be putting a Kicker 12" L5 Series sub in my truck,I'm not sure what amp I'm getting yet though,should I use a capacitor with this sub?
Old May 8, 2009 | 05:45 PM
bigdog87's Avatar
If your lights dim when it hits, I'd put one.
Old May 8, 2009 | 06:05 PM
styxnpicks's Avatar
when your alternator doesn't put out steady voltage
Old May 8, 2009 | 06:21 PM
bigdog87's Avatar
OP, he ^ knows more than I do.
Old May 8, 2009 | 07:16 PM
JJDH's Avatar
http://www.bcae1.com/. caps are worthless.especially in new vehicles, when the alt dips, the cap is usually discharged, repeat 10,000 times, still same result. need a good battery, it has more storage. even a small second battery if necessary. is better than an cap. if ur alt is ho, then a cap could make sense when all ducks are in a row, alt, battery, demand, need for the kick in the trunk..........
Old May 8, 2009 | 07:19 PM
JJDH's Avatar
no
Old May 8, 2009 | 09:29 PM
kuruption's Avatar
When do you use a capacitor? Never.
Old May 8, 2009 | 09:56 PM
styxnpicks's Avatar
petty much. most vehicles these days have alternators that put out steady voltage thanks to properly designed voltage regulators. no if you hooked it up to an o-scope and found that you have dc ripple in the charging system then you would need a cap
Old May 9, 2009 | 02:14 AM
Low_e_Red's Avatar
Houston, we have a winner!
(however it would be AC ripple in the DC line...)
