What amp with 1 Image Dynamics 10"
Old Mar 10, 2009 | 10:18 PM
Someguy's Avatar
Im going with the Supercrewsound box with 1 Image Dynamics IDQ10D4 v.3 10 inch Subwoofer http://www.supercrewsound.com/commer...dId=5&catId=86
My head unit is Pioneer AVIC-F700BT. I have another 1000ish to spend on amp/s, front componets and some cheap rear fill. Any sugestions to complement those partiular sub?
Old Mar 10, 2009 | 11:43 PM
mSaLL150's Avatar
Get a fatty 4 channel, run your components off the front 2 channels and bridge the back 2 to power the IDQ. With 1000 bucks, you can get a SOLID 4 channel and some very nice components.
Forget rear fill. Unless you REALLY want it, then just run something cheap off the HU.
Old Mar 10, 2009 | 11:44 PM
Someguy's Avatar
Forgot to add this is going in an 04 SCab. I listen to everything, but mostly rap and rock. I hope the ID will give me enough clean bass over the stock audiophile system.
Old Mar 11, 2009 | 07:26 PM
Someguy's Avatar
So I changed it up a little heres what its going to look like..
Pioneer AVIC-F700BT
2-IDQ10D4 v.3 in supercrewsound enclousre.
6-1/2 Focal 165 V1-Fronts-
Focal 570 CA1 Rears Ran off head unit.
Diamond Audio D6 1000.2 for the subs
Diamond Audio D6 450.2 For the fronts( Overkill for the front?) so maybe a JL Audio G2250
What do you think? Money well spent?
Old Mar 11, 2009 | 08:14 PM
Sundevil2188's Avatar
Pioneer AVIC-F700BT
Sounds killer man. You'll have a killer set up with that.
Dont forget to budget for wiring and possibly some deadening
Old Mar 11, 2009 | 08:37 PM
7lug's Avatar
Pioneer AVIC-F700BT
So much for that 1k budget...
Old Mar 11, 2009 | 08:54 PM
Someguy's Avatar
HAHA. Im stimulating the local economy...
Old Mar 11, 2009 | 09:06 PM
7lug's Avatar
That's fine and it should sound good, but you can do better, especially on those amps...
Old Mar 11, 2009 | 10:03 PM
Someguy's Avatar
Im open to suggestions, I havent ordered the amps yet.
Old Mar 11, 2009 | 11:50 PM
7lug's Avatar
Im open to suggestions, I haven't ordered the amps yet.
Cadence iA7 and iA2 for $570 shipped with a 5 year warranty. VERY solid amps that have great SQ and are underrated as well...
http://www.powermaxelectronics.com/
Old Mar 12, 2009 | 02:52 AM
mSaLL150's Avatar
I run Cadence iA series amplifiers in my truck. Very nice amps. However, the Zapco DCs are just as capable power wise and also have the processing ability for an active front stage.
Old Mar 12, 2009 | 09:05 AM
Someguy's Avatar
How about this:
Fronts-Zapco DC350.2
Subs-Cadence ZRS-3002 - Cadence 1200
Explain "active" front stage with the digital processing over a regular signal please..
Old Mar 12, 2009 | 11:01 AM
7lug's Avatar
Wow, you went from Cadance iA's to Zapco reference DC? Why not just go to Arc SE's or Audison ZRX too...lol Those amps are NOT in the same category and I was trying to stay within a budget for someone who was going to dump $900 on some Diamond Audios.
As far as active, who's gonna tune it, the OP? Active x-overs are nice, but they are work and they are in a CONSTANT state of tune, there's a reason why 90% of normal people run a quality passive x-over, cuz they work and work well. Active takes a good ear, and I don't mean great hearing...lol
Old Mar 12, 2009 | 11:36 AM
mSaLL150's Avatar
My bad, i am getting threads mixed up. I thought this was the guy who was set on a Zapco DC for his front stage and you were saying to go with iA amps. I would def take the iAs over the diamonds.
Passive x-overs do work well, but are not designed for the environment they are typically put in. but yes that is beyond most people.
Old Mar 12, 2009 | 11:38 AM
7lug's Avatar
How about this:
In simple terms, when you hear music, it is in "full range" meaning it includes all of the frequencies generated by the musicians and instruments. Well, within the structure of a speaker system, those frequencies need to be divided up and sent to the appropriate speaker designed to reproduce that frequency range, for instance if it is bass below 100hz, then it is sent to the subwoofer, over 100hz it is sent to the midbass/midrange etc etc. A passive crossover takes a + and - from 1 channel of the amp and distributes the sounds through a series of capacitors to the proper speakers, usually 2 or 3 depending on the set. So it takes a single signal and divides it up sending some to the midrange and some to the tweeter and determines the dividing point (crossover point) based on the characteristics of that speaker as designed.
Active crossovers are powered crossover networks with frequency filters and have gains built in (volume). They are speaker specific meaning they take 1 channel from the amp and send it a user requested frequency to 1 speaker, either a tweeter, a midrange, midbass, or a subwoofer. So for as many speakers as you plan on running, you need that many amplifier channels, again because every speaker will have it's own channel. If you run a 2-way set (midrange/tweeter) then you need 4 channels of power. Setting crossovers is not just a set it and forget it type ordeal as frequency response, range and gain (volume) are all adjusted. If you don't recognize things like Fs, F3, Qts, etc then tuning it correctly will be someone elses duty as these parameters vary from speaker to speaker, even if they're of the same size from the same manufacturer.
I've had both and they both have their pros and cons. Again, for 90% of the people, a solid passive crossover network will make "beautiful music"...lol
