Sub location
Old Feb 22, 2009 | 11:53 PM
clc0438's Avatar
Sub location
Hey, I'm going to buy two 10" compvx kickers. I've got a 2004 Ford F150 FX4 Supercab. So I have a few questions..
If you need this info: 1 sub has 600 watts rms, the amp is 1500 watts.
1) What would be the best box to get the most bass out of these? I like to listen to mostly hip hop, and when the mood is right some country =).
2) What direction would be the best place to place these?
Thanks for the help.
Old Feb 23, 2009 | 05:00 PM
clc0438's Avatar
Anyone? 20 people are viewing this and no one has a clue?
Old Feb 23, 2009 | 06:33 PM
C. Whammy's Avatar
the "best" box to get the most output would be a 4th order, but you're not gonna fit that without taking out your back seat.
how much space are you willing to sacrifice?
Old Feb 23, 2009 | 08:45 PM
yetti96's Avatar
Downfacing under the rear seat is popular but I am not sure you will get those subs under there without a seat lift.
Old Feb 24, 2009 | 05:12 PM
clc0438's Avatar
How much will I have to lift it?
Old Feb 24, 2009 | 09:59 PM
4X4AUTIGER's Avatar
yeah they almost have 6" mounting depth so you would have to get a seat lift. LMI makes a good one. google it
Old Feb 26, 2009 | 01:31 AM
mikeltn's Avatar
check out supercrewsound.com The build the boxs and should have the liftsat worst you'll have to use the standard 3" lift. If you take a look, the website has some info about removing the magnet cover on the subs and you might be able to lose about a .25" of the mounting depth. If you can get to 5.75, you won't need the seat lift.
