enclosure volume
enclosure volume
does anyone know how to calculate the enclosure volume for a sub using the specifications for it? its been awhile since ive done it and cant remember exactly how?
Specifications: * Power handling: 500 watts RMS/700 watts max * VCdia: 2-1/2" * Le: 2.50 mH * Impedance: 4 ohms * Re: 3.1 ohms * Frequency range: 22-500 Hz * Magnet weight: 100 oz. * Fs: 25 Hz * SPL: 89 dB 2.83V/1m, 86 dB 1W/1m * Vas: 2.27 cu. ft. * Qms: 7.03 * Qes: .49 * Qts: .45 * Xmax: 18.7mm * Dimensions: Overall Diameter: 12-1/2", Cutout Diameter: 11-1/8", Mounting Depth: 6-1/2".
any help would be appreciated
nevermind i think i may have figured it out. 1.173 sealed and 3.437 vented with a 5"x 47.88" port. would make tuning around 23.11hz. does that sound about right? or am i missing something
i think ill just go sealled thats alot of box volume and would be a lot fiberglassing to try and tuck it in this screw. but thanks for the input.
