Tweeter Mounting
Not much of a point to unless you can aim them up. I'd only do that if I had a descent headunit/dsp to adjust timing. Which I do, but I don't think the benefit is big enough to cut the panels up.
My Edge pod sits in the area to mount them by window. I was looking at mounting them like in my first post because the tweeters are 1" and the flush mount has a 1/4" collar all the way around so they won't fit inside the door. I can dremel out the hole to make the tweeter fit but the collar won't fit. without trimming it as well. I did see anothe pic where they notched out the top part of the stock location so the collar could tuck up inside there. I just can't find that pic now.
You have to take the whole door panel off. It's just a matter of a few screws and bolts, remove the speaker, and lifting. They didn't interfere with the defrost vents at all in the location I installed them (reason I put em there). that was also the flattest spot I could see for a good mount.
