2003 F-150 Sound system
This is my first post, and my first truck.
I am thinking about buying this setup for my truck:
Kicker ZX250.2 Power Amplifiere
2001-2003 Ford SuperCrew Cab Single Sub Box Sub Box
- Speaker Hole Size 10"
Kicker CVT-10
Everything can be found here - http://caraudiofactory.com/
Can someone give any thoughts on this setup? By the way the Head unit is not factory. Thanks in advance for all the help.
Kicker CVT-10
if its your first system then you will probably be happy with this.
kicker's are generally known for being more of an SPL sub (loudness) and less of an SQ sub (sound quality), but they are pretty inexpensive
what are you looking for, sound quality or lots of volume?
there are a ton of brands out there you have probably never heard of that might suit you better
I want Sound Quality. Do you have any suggestions as to what setup I should go with? The Aftermarket stereo that I have installed is: Dual XDVD8183
Last edited by thirdcoast_318; Oct 31, 2008 at 08:29 AM. Reason: add type of Aftermarket stereo
