Sub issue :{
Old May 12, 2008 | 07:42 PM
red99l!ghtning's Avatar
Sub issue :{
Hey guys, not my setup in my truck but its about my buddies in his expedition and if figured yall could help, He's got a Kicker 1000.1 amp and 2 T1's in a pro box, they sound great but when you watch them hit one side seems to be moving ALOT more than the other one. what could be all the causes of this? wiring seems fine.
Old May 12, 2008 | 07:46 PM
mSaLL150's Avatar
They are probably wired incorrectly. One sub is getting more power than the other. One is probably wired series and the other parallel. Make sure they are both wired the same way, and wired for the proper resistance (ohm) load.
Old May 13, 2008 | 12:27 AM
The wiring seems to be good, its set up for 2 ohm tot he amp, my question is with the probox he has to speaker wiring outlets on either side, whats the best way to combine the to and run it to the amp?
Old May 13, 2008 | 12:29 AM
fdimeroller's Avatar
did u check the fuses? if the amp has more than 1 fuse one could be blown but it could still be workin (saw that happen last week in a buddies car)
Old May 13, 2008 | 02:03 AM
There no fusees on the amp :[
Old May 13, 2008 | 08:32 AM
1bad86vmax's Avatar
Are the subs single or dual voice coil ? What Ohm rating are they ?
Old May 13, 2008 | 10:53 AM
dual 2 ohm, got them wired the same way i had the dual 2 ohm treos i had before.
Old May 13, 2008 | 12:51 PM
1bad86vmax's Avatar
So you have it wired like the picture ?
Old May 13, 2008 | 04:26 PM
exactly
