Bass control management Help
Old May 9, 2008 | 05:13 PM
shanecaseber's Avatar
Ok hears the deal I got a Jensen DD because it was a good deal on ebay any way the bass control on this HU well stinks when I adjust the HU eq to thin out the doors the sub bass cuts as well I was thinking of adding a SOUNDSTREAM BX-12 BASS BOOSTER CAR PROCESSOR EPICENTER or some kind of something to fix this dilemma I looked at a few eqs with sub outs but no sub in just main in I want to still use my sub out rca from the HU .
Old May 10, 2008 | 11:18 AM
Well I ordered a SOUNDSTREAM BX-12 BASS BOOSTER CAR PROCESSOR EPICENTER looks like what i need http://cgi.ebay.com/ebaymotors/SOUND...spagenameZWDVW
Old May 20, 2008 | 04:43 PM
man this lil black box did the trick
Old May 20, 2008 | 04:53 PM
mSaLL150's Avatar
sweet. what are the specs on your whole system? (speakers, subs, amps, wiring?)
Old May 20, 2008 | 05:41 PM
I have 2 element design 11Kv.2 Subwoofer, Jensen's VM9022 DVD receiver, 10 inch under back seat,Sony Slim Series XM-1S Mono class D and a Sony the Slim Series XM-4S 4 ch amp ,4 Pioneer TS-A6982R 6"x9" 4 way speakers in doors ,1 TS-A1682R 6-3/4 4 way for center Channel ,street wire install stuff and the new black box
Old May 20, 2008 | 05:55 PM
mSaLL150's Avatar
Cool. How do you like those ED subwoofers??
Old May 20, 2008 | 06:03 PM
they are the slim ones in a small box they do the job well and now they slam with the bass control my HU was killin them
Old May 20, 2008 | 07:04 PM
1bad86vmax's Avatar
Dude , why does it look like your amps are powered with 10 guage ? I would use 0- 2 guage for the main power wire to the battery . I would then use a fused distribution block where yours is , and run 4 guage to each amp .
Old May 20, 2008 | 08:23 PM
Its with in range for 4 guage with a split to 8 guage the amps are very efficient on power I did the math
Old May 20, 2008 | 11:35 PM
styxnpicks's Avatar
"very efficient" is the term used to describe not powerfull
Old May 21, 2008 | 06:12 AM
50 watts RMS x 4 channels at 4 ohms and 500 watts RMS x 1 at 2 ohms whats not powerful about that. Why do you think I should step up to thicker wire?
Old May 21, 2008 | 06:27 AM
styxnpicks's Avatar
weaksauce... 4ga distributed to 8ga is fine as long as its real copper wire and not that not cca crap
Old May 21, 2008 | 06:36 AM
weaksauce... ???? its good wire they way I seen it was a 7 to 10 ft run pulling up to 120 amps is fine for 4 gu wire
Old May 21, 2008 | 07:52 AM
kuruption's Avatar
4ga to 8ga should be fine considering it's a 700 watt system and the power run is only about 10-12 feet. If you notice dimming when the bass hits and you upgraded your "big 3/4" to 4ga, I would possibly recommend moving to 0/1ga for the "big 3/4" but you shouldn't need to.
Old May 21, 2008 | 08:26 AM
I am getting dim lights on some bass notes whats the Big 3/4
