Plug and Play my A$$
Just bought and 07 audiophile HU and an OEM Sub. The subwoofer harness is like 16-pins and the Aux out put is 8-pin. WTF? Anyone know how this works? what do i need to do? Went to FORD they said we outsource our Stereo stuff. Please help!
The extra four wires are the power and ground for the factory amp. Two power and two ground. If you don't have the stock harness, then it's going to be rough figuring it all out. The problem that you will run into is that all of the pins are not used.
This really sux! everything i read on here prior to buying this stuff said, If your trucks prewired (which it is) then the one end will plug into the sub and the other in the back of the HU. Where do i get the stock harness? i know im not the 1st one to do this. can anyone help???
