Finally done with my sound system install!! PIX INSIDE
As some of you guys may know, I have been installing a system in my truck.
Here are the final results of my hard work..
This is what my system consist of:
Avic D3
Kicker ZX1000.1 & ZX650.4
2 Kicker L7 10's
2 sets of Pioneer TS-C720PRS F+B
The install look very clean and much nicer than in these pix, it was dark out so I had to use a flash.
It was alot of hard work & lots of hours, but im very pleased with the results.
Avic D3
2 Kicker L7 10's
Hey thanks Low
The capacitors LED's were very bright and as you can see in the pix I put a dark tint over them. This is temporary till I nite shade the plastic cover for a better look. I sunk it into the box cuz it was pretty big
and chrome which I did not like much.
I still have not dialed the system in 100%, but it does sound very crisp & clean and can take alot of power. Im very pleased with the sound
Im getting a rattle in the headliner and map lights
that I still need to get taken care of.
Here is a day pic I just took.
The capacitors LED's were very bright and as you can see in the pix I put a dark tint over them. This is temporary till I nite shade the plastic cover for a better look. I sunk it into the box cuz it was pretty big and chrome which I did not like much.
dang that install is clean. you do all your own work. if so your nice. give it an a+ for home install
are those boxes to spec. how do those solo's handle on the mid to high bass. i know they put down the deep but never heard there mid's
I have not had a chance to fully crank it since im still breaking in the woofers.
But from what I have, everything sounds clean and balanced.
Pat, that is a capacitor your seeing.
I have had my good eye on those same Pioneer components for a few days now. Apparently you are pleased with them. I think they are rated at 50W RMS? How much power does that amp send to them? I am thinking of putting them up front only and getting an amp with 65W per channel to push them. I am pretty new to all this though. Is 65W too much, would 40-50 be plenty?
Originally Posted by andrewc_11890
Looks good, must sound good too
