w7 or type r
Originally Posted by Bartak1
Doh! I didnt realize he said one W7 or two Type Rs. Two Type Rs should murder a single W7 in output....
That must be one hell of a factory freak....
This one's been kicked around over an over but from a pure SQ point of view the 12w6v2 sounds better than the 12w7 with a little less output and is certainly less expensive.
Type R = Poo loud fart cannon with a little SQ. From an SPL perspective you can get multiple cheap and power the crap out of them for good numbers.
One of Alpine's factory trucks sits right down the street from me it's got 8 12" type R's with 2000 watts
I let the Alpine guy listen to my last install in a Nissan Frontier it was a 12w7 on a Zapco 6.0 so around 1000 watts in a 2.5 cu ported box. From a SQ perspective I bet mine was within 5db of his system and it just killed his in SQ and I only had 5 speakers in the truck the Alpine truck has more than 20. You should have seen the look on his face, priceless.That's what you get when you spend hundreds of hours and $$$$$ 5 figures on an install.
James
James
Originally Posted by 97f150kid
im going for sound. what can i get for cheaper the a w7 that out performs it? im looking for only a single 12, but if need be, ill go two
12w7 or 2 type r 12's?
i like the look of the w7, but the type rs are soo much cheaper, what would you guys go with?
Originally Posted by TigerFan23
Where in the H are you going to put a W7 in an f150? The boxes I've seen for them are enormous even in SUVs
OHHHHHH come on now, you dont need a back seat, passengers seat, middle console, or drivers seat.....all your passengers can sit on the sub box
lol....will the w7's even fit under the rear seat with a seat lift? i mean those subs are freaking huge
edit: holy hell that w7 has a 9.5" mounting depth....that wont fit under the rear seat even with the seat lift lol
Bryan did fit a pair of 10W7s under his Screws back seat...although they were forward firing instead of downfiring.
cool......box and subs would stick out quite a bit still cause the end of the sub is like 13" total height then theres like 1.5" for the box....so it would have to stick out quite a bit i assume....and then adding the grills on the subs is a must so no one accidentally bumps the subs with there foot
wonder how it looks.....got any pics or links?
