what's wrong with my sub??
Old Feb 13, 2008 | 02:22 PM
306stang's Avatar
so my sub stopped working. or should i say it works when it wants to.
with a signal going to it in normal operation it doesn't work.
when you push ever so slightly on the cone/surround it starts to work again.
any ideas???
voice coil shot maybe
Old Feb 13, 2008 | 02:48 PM
Crewwzin's Avatar
any ideas???
The tensil leads on the back of the sub most likely have a cold solder joint. If it's easy to get too, it shouldnt be too hard of a fix. If its loose inside the motor structure, then you need to contact the manufacturer and see if they will warantee it. Good luck.
Old Feb 13, 2008 | 04:38 PM
306stang's Avatar
super dooper
thanks crewwzin
Old Feb 13, 2008 | 09:12 PM
Crewwzin's Avatar
no prob, man. What kinda sub is it? Where'd you get it? You might be able to get a warranty claim out of it.
edit: just read your sig and noticed its a Kicker. they've got a pretty good claims dept.
Old Feb 14, 2008 | 10:18 AM
306stang's Avatar
even if it's two or three years old and i don't have the box or receipt?
i even doubt the local store would do anything
Old Feb 14, 2008 | 11:57 AM
Crewwzin's Avatar
Hmm...nevermind then. You'd probably be better off just buying a new one. I think BB in Destin has some open box stuff right now that you could pick up pretty reasonable. If not there, I know Sound Solutions in Niceville has some Kickers they're trying to get rid of.
Old Feb 14, 2008 | 06:21 PM
306stang's Avatar
well if i gotta get a new sub i'd prefer to get a shallow mount b/c of the damn seat or maybe even mounting behind the back seat..
do shallow's sound as good as regular's?
Old Feb 14, 2008 | 06:36 PM
Crewwzin's Avatar
I dont think you're gonna get it behind the back seat. Its a little too cramped back there. From what I've heard, the shallows are comparable to regular subs. But there are plenty of regular subs that will fit under the seat with plenty of room to spare. Anything with a mounting depth of 5.5 or less will do nicely.
Old Feb 14, 2008 | 08:25 PM
DRJ's Avatar
DRJ
yeah bad sub... it's going out
Old Feb 14, 2008 | 10:02 PM
Low_e_Red's Avatar
Im definately not a fan of a few of the shallow mounts. Some are nice but others... Ehh.
Old Feb 15, 2008 | 02:07 PM
Devildog101's Avatar
How far is Destin from Tampa?
Devildog101
Old Feb 15, 2008 | 02:28 PM
Crewwzin's Avatar
Devildog101
'Bout 8 hours. Its right between Panama City and Pensacola.
Old Feb 15, 2008 | 03:48 PM
306stang's Avatar
so let's start compairing subs. this has probably been beaten to death but whatever.
kicker
audiobahn
clarion
id
what?
right now i've got a kicker 200.2 amp (yes i know it's very weak)
i would eventually like to push a sub with 600-400
i want the sub to be loud and clear.
any ideas
Old Feb 16, 2008 | 05:44 PM
306stang's Avatar
so i took to sub to a local shop i trust. verdict - a voice coil is bad.
so now i'm looking at shallow mount kicker's. either 10's or 12's
if i run 10's i'll get a kicker 500.1 amp
and
if i run 12's i'l get the 750.1 amp.
prices for both setup's are roughly the same.
has any one mounted shallows behind the back seat of an 05 ext cab.
i don't listen to a lot of rap so i'd be going for loud quick bass, ie rock.
the tweleve's are gonna give me deeper bass but not hit the faster notes however the ten's will do the opposite.
the guy said 12's might be able to go behind the seat but it would def be a fiberglass enclosure
Old Feb 16, 2008 | 06:17 PM
Crewwzin's Avatar
and
hmm...I'm not so sure about that. Theres barely enough room for amps back there, much less trying to get 1.5-2ft3 of air space. I have seen a couple of guys on here that have made brackets to bring the seat out a little, but even then, it would still be cuttin it close. What shop did you go to?
