Which Kicker amp
Which Kicker amp
I need to know which amp to run with my 2- 12" kicker L7s 2ohm. I get the subs and amp for free so please help me. which will be the best amp to power those subs. oh and also is there any difference in the 08 and older kicker L7s
Originally Posted by Tuff4rd
I would say zx1500.1, i just ordered a zx1000.1 & a zx650.4....I will be running 2 10inch L7's...
Originally Posted by 306stang
and how are you getting this stuff for free???????
this will be interesting.
Originally Posted by skiptemp
Tuff is right! I was under the understanding the amps would see 2ohm. After pulling the spec up for the L7, the amp will see 4ohm. Therefore the ZX1500.1 for each sub would be best. The ZX1500.1 will push 750W at 4ohm with 14.4volts.
1 Dual 2's = 4 or 1
1 Dual 4's = 8 or 2
1 Sing 2's = 2
1 Sing 4's = 4
2 Dual 2's = 8, 2 or .5
2 Dual 4's = 16, 4, or 1
2 Sing 2's = 4 or 1
2 Sing 4's = 8 or 2
Originally Posted by Low_e_Red
No... They will be at a 2 ohm load.
1 Dual 2's = 4 or 1
1 Dual 4's = 8 or 2
1 Sing 2's = 2
1 Sing 4's = 4
2 Sing 2's = 4 or 1
2 Sing 4's = 8 or 2
1 Dual 2's = 4 or 1
1 Dual 4's = 8 or 2
1 Sing 2's = 2
1 Sing 4's = 4
2 Sing 2's = 4 or 1
2 Sing 4's = 8 or 2
FX4; you need to give us more information as to what you have in mind.
1. witch L7 D4 or D2?
2. How many amps do you want to use?
3. How do you plan to wire each sub (Parallel or Series) and how do plan to wire the subs to a amp(Each or together).
Their D2's. Like i said before i get this stuff for free, so if 2 amps will be better then i will do that. i dont know what parallel or the other stuff means. i just want it lound as ****. so if you guys could just tell me that would be great.
thanks
thanks
