Amp Wiring
Old Jan 30, 2008 | 04:44 PM
moptopklee's Avatar
Amp Wiring
i have a 2007 f150 supercrew
i wanna know how to run the power wire for an amp to the battery which side should it go on drives or passenger and just like how do you run it and where
and what about the RCA
Old Jan 30, 2008 | 04:56 PM
coobies5's Avatar
All depends on where you mount the amp, I have my amp under my drivers seat, and the power wire is ran along driver door panel, and rca's are ran on passenger side. I don't know if 07's are like 01's, but there was a rubber grommet not too far above the brake and gas pedals that wasn't being used, and i just popped it out and ran the wire from the battery through there and under the carpet, I believe that is the spot most wires are ran from if you have something outside the cab that needs to be routed inside.
Old Jan 30, 2008 | 04:58 PM
moptopklee's Avatar
well the only problem is the battery is on the passenger side
Old Jan 30, 2008 | 05:12 PM
Mr. eXtreme's Avatar
Whatever you do... Always run your RCA's and Power wire down seperate sides of your truck.
By not doing this you'll have noise problems...
I have my amp mounted under the passanger side of my rear seat and have the power wire running out the gromit above my brake pedal then across the firewall and to the battery. Also make sure you place your fuse no more then 18" away from your battery. And don't be afraid to use some zip ties to keep thing where you want them.
Good Luck
Old Jan 30, 2008 | 05:24 PM
moptopklee's Avatar
alright thanks man
Old Jan 31, 2008 | 01:20 PM
Low_e_Red's Avatar
Search!!! Multiple Threads On This!
