Hi/Mid replacement
Old Jan 23, 2008 | 04:52 PM
Buckeyes's Avatar
Hi/Mid replacement
I have two questions:
Does anyone make a good 5x7 component set?
Is it worth it to replace the rear door speakers in a SuperCrew?
Im about to install a system and hi/mid sound is very important to me. I have heard other people say that replacing the rear speakers is pointless because the subs drown them out. True/False?
Old Jan 23, 2008 | 05:20 PM
styxnpicks's Avatar
OMG search n00b
Old Jan 23, 2008 | 06:56 PM
skiptemp's Avatar
Originally Posted by styxnpicks
OMG search n00b
Steady styxn don't blow a woofer; remember patients is a virtue.
Old Jan 23, 2008 | 11:28 PM
HEC*'s Avatar
i replaced all the door speakers with 6.5" Soundwaves each 200Watts RMS running off a 1000 Watt Crunch Amp
Sound is Tone Deafening !!!!
at 3 clicks is normal sounding
at 1/4 volume its as loud as my stock speakers would go at full volume
at 1/2 volume i walk out truck rubbing my ears.
The doors had to be shaved a little to fit the magnet but not much.
Sound is awesome !
Old Jan 23, 2008 | 11:35 PM
GJ Screw's Avatar
OMG search n00b
Hey, as long as their is not 10 new threads by the time i get up for work, were all good!
I have a pair of JL zr570 for my front stage- running off a JL 450/4 and it sounds great imo..
Jon
Old Jan 24, 2008 | 12:32 AM
styxnpicks's Avatar
Sound is awesome !
gaurantee your amp is not 1000 watt rms
Old Jan 24, 2008 | 09:53 AM
Devildog101's Avatar
Probably 1000 watts wls (when lightning strikes)...
Old Jan 24, 2008 | 10:24 AM
Buckeyes's Avatar
Stynx- if you arent gonna help then keep it movin. I dont sit on these forums everyday-allday, just wanted to post a fresh thread to hopefully get some ideas.
Old Jan 24, 2008 | 11:41 AM
styxnpicks's Avatar
want a cookie?
no
no
false
happy?
Old Jan 24, 2008 | 12:35 PM
HEC*'s Avatar
For 4 door speakers this is more than enough, i have another 1200 Watt Crunch amp for the subs under the seat.
these are the specs
Specification
1500W 1-Channel A/B Class Mono Amplifier
375W x 1-Ch @ 4-Ohms
750W x 1-Ch @ 2-Ohms
1500W x 1-Ch @ 1-Ohms
Speaker Lead High-Level Inputs
Feature: SEPP A/B-Class
Illluminated, Large New Design Crunch Logo
1-Ohm Capable A/B Class Mono Block Amps
Rugged MOSFET Audio Outputs
PZi Amp Protection w/System Dignostics LED's
Oversized Speaker Terminals
Silver Preamp Level RCA Inputs
Old Jan 24, 2008 | 12:48 PM
styxnpicks's Avatar
these are the specs
Specification
so wait....... you have an A/B class mono block powering your full range drivers....
BWAHAHHHAHHAHAAHAHA
sorry but with 2 30 amp fuses you MIGHT have a 550w rms amp
and not stereo imaging?
dude you got HOSED
Old Jan 24, 2008 | 01:11 PM
Buckeyes's Avatar
no i dont want a cookie, no reason to be an a$$. if you dont have anything constructive then kick rocks. just about every post with your name on it has a kind of "a$$hole-ne$$" to it. i bet these forums are the only time you can act like you have a pair, and i see you have a few co-signers that seem to get off everytime you try to make someone look like they dont know what they are talking about. but dont get your panties in a bunch Nancy, i will make sure the next time i have a question i will check if the one and only Styx hasnt already discussed it in another thread. thanks for the answers to my questions Ma'am
Old Jan 24, 2008 | 01:41 PM
Low_e_Red's Avatar
CHILL CHILL!!
If you really want a set of 5x7 components I have a set for sale. JL XR570CSi.
Cosigners.....? And these would be....
P.S. The only reason we "co-sign" is because he knows a decent bit. Yes, very opinionated but normally right.
Old Jan 24, 2008 | 01:43 PM
Low_e_Red's Avatar
BWAHAHHHAHHAHAAHAHA
dude you got HOSED
I KNOW AHAHAHAHAHAHA!!!! But whats even better is he posted the specs to a 1500W when he said earlier that he has a Crunch 1000....
Hes an UPPER. Got to UP you and I.
Old Jan 24, 2008 | 01:53 PM
HEC*'s Avatar
Yeah i posted a 1000 and when i looked at the box saw the 1500...
Want me to edit it?
Wow...
I didnt know this went on here on this message board...
Since when did they give licenses to Children? With your FX2 Cheap *** !
