Speakers cutting out
Old Jan 20, 2008 | 08:23 PM
swhite005's Avatar
2006 F150 Lariat
Replaced stock HU with Kenwood 6019 Nav/Double DIN
Started with the right front speaker cutting in and out intermitantly. Replaced all butt splices with solder. Everything worked well until recently, now right front and rear and left rear occasionally cut out. I havent had a chance to pull the HU out again to check connections, but thought I'd get your opinions. Does this sound like a bad connection or bad ground? Or does it sound like speakers going out or HU failing? Thanks for your advise.
Old Jan 20, 2008 | 08:24 PM
swhite005's Avatar
I've had new HU in for about 8 months...problems started approx 2 months ago
Old Jan 20, 2008 | 09:26 PM
DRJ's Avatar
DRJ
Originally Posted by swhite005
2006 F150 Lariat
I would say bad connections, the butt connectors are probably loose
Old Jan 20, 2008 | 10:56 PM
Low_e_Red's Avatar
Since the butts are already out. Are you using heatshrink or Electrical tape? Check those connections sounds like they may be grounding either into each other or to metal.
Old Jan 21, 2008 | 12:00 AM
swhite005's Avatar
I Used Electrical Tape, Is That A Bad Idea? I Have Heat Shrink I Could Use....would That Be Better?
Old Jan 21, 2008 | 12:22 AM
Fabian06SC's Avatar
how odd, i have a 6019 too, and mine started doing that about a month ago.
my two fronts cut in and out and sound staticy when the volume is below 15
after 15-16 they play fine.
I took the stocks out and have a pair of kenwood 5X7s up front.
wiring is all like stock, used interconnect adapter from the hu to the factory harness...
the adapter wires were cut, and the hu wires were all shortened and re-pinned to the adapter.
OEM Speaker connections were soldered on the new speakers so the factory plug plugs right in.
i think my speakers are just bad, im going to swap in the factory ones to check it out.
opinions?
Old Jan 22, 2008 | 12:30 AM
Low_e_Red's Avatar
Not necessarily. Go back through and recheck everything. It may require undoing every tape job and retaping individually again. Things are odd sometimes.
If that doesnt work try rewiring the harness again.
If that doesnt work try checking the speakers.
If that doesnt work run all new spk wire.
If that doesnt work buy a Pioneer, Eclipse or Alpine and get rid of that Kenwood.
p.s. dont buy another.
Old Jan 22, 2008 | 12:06 PM
Devildog101's Avatar
Cold solder joint??? You said just the fronts cut in/out? Is it worse now that you sodered them?
Devildog101
Old Jan 22, 2008 | 03:08 PM
Low_e_Red's Avatar
Devildog101
Thats kinda what I am wondering... Thats why i said rewire it.
