subs?
Old Jan 14, 2008 | 10:29 PM
jmt0645's Avatar
subs?
i know this has probly been beat into the ground, but, what in your opinion is the best SQ/SPL driver under $250 a piece. i'm looking for 2 12's that can handle ~1200 watts RMS. ohm load does not matter as my soundstream amp puts out same power with 1-4 ohm loads. as always, thanks guys!
Old Jan 15, 2008 | 12:02 AM
Bartak1's Avatar
SI BM, Diamond D6 (kinda need a little more power for those though), RE SE, Soundplinter Rli (hell even RLP)......
Few to look at anywho.
Old Jan 15, 2008 | 12:21 AM
Texasflawlessme's Avatar
wuts the difference in Ohms?
Old Jan 15, 2008 | 10:22 AM
jmt0645's Avatar
i knew i could count on you Bartak! thanks.
Old Jan 15, 2008 | 01:31 PM
scottbigred's Avatar
ohms=resistance/impedance
Old Jan 15, 2008 | 10:24 PM
lower or higher betteR?
Old Jan 15, 2008 | 10:38 PM
jmt0645's Avatar
depends on the amp you plan on using. the lower the ohm rating= the more power the amp delivers, higher ohm just opposite. but there are amps like mine that put out the same power regardless of the ohms it sees, but the lower the ohm the easier it is to give you that power and the less it pulls from the charging system.
