Screw sub setup ?
Old Jan 8, 2008 | 03:18 PM
Ron_b's Avatar
Screw sub setup ?
does anybody have this or know that it willl work.
a 04+ supercrew with 3 10inch subs under the back seat, also you can mount the amp behind the rear seat right?
pics and info please.
thanks
Old Jan 25, 2008 | 11:22 AM
Verytalonted's Avatar
I don't know about 3 10's but http://supercrewsound.com should be able to help you get 2 in there...
Old Jan 25, 2008 | 12:10 PM
carguyingeorgia's Avatar
thanks
From my research before I did my install, I would think there are going to be a couple of problems with trying to get 3 10's under the seat.
1. With 2 subs, because they are mounted underneath the sides of the seats and not the middle, they have enough mounting depth. For a third, you would probably have to mount it under the center of the rear seat where the transmission hump is, and you would have a much shallower mounting depth.
2. Even if you do get 3 subs in a box, you will need to have enough air space inside of the box for them to sound good.
I'm not saying you couldn't do it, but to account for these two factors you would definitely have to have a seat lift in order to accomodate this big of a box.
Old Jan 25, 2008 | 03:46 PM
styxnpicks's Avatar
you would have to have shallow mount subs, and they would have to fire up, 4 8's or 2 12's might be a better option
Old Jan 25, 2008 | 06:18 PM
Low_e_Red's Avatar
Psshh... 4 8's bet that will sound terrible...
Old Jan 25, 2008 | 08:08 PM
skiptemp's Avatar
Low_e;
be kind....8"s work if done right!!
Old Jan 25, 2008 | 11:29 PM
styxnpicks's Avatar
Originally Posted by skiptemp
Low_e;
he's joking, he knows 4 8's have more cone area than 2 10's he's just trying to make a personal jab at me cause I'm running 4 8's
Old Jan 26, 2008 | 12:57 AM
Low_e_Red's Avatar
Caught me...
Old Jan 26, 2008 | 03:38 AM
mSaLL150's Avatar
so they're up and running now? i thought you hit a roadblock in the installation process...
3 shallow 10s can easily work well with a seat lift...
