will it sound bad mixing 6.5comps
2 X 12 L7 will definetly occupy your whole back(including 3rd row sit space) to get the right cubic inch for them subs.
also...make sure that you get the dual 2ohms so you can wire both subs to carry a 2 ohm load to fully utilize the amp.L7's are power hungry and they will sound like crap if not fed with the right amount of power.
well with those dimensions it will give me 6.5cu ft and take away the .5 for the subs displacement and then even say 1cu ft for the port gives me around 2.5 per sub that isnt enough the max reccommend is 3.25
so i will have maybe 1cu ft per sub
well some guy at car audio that said he could build me a box with those dimensions and that tune and be 2.5 per sub wow i am lost in how to get 2 12's in my truck
what if i go with the max dimensions being 26 long 35 deep and 17.5 wide
whats the biggest subs i can get in there can i get 2 12's or 2 15's, or one 15 and what would be the loudest
i am trying to get a box to sit in place of my rear console in my KR and i dont kno if its possible i am so frustrated
Originally Posted by styxnpicks
those dim's do not add up to 6.5 cu ft, 5.33 before sub and port displacement. and with how low you want to tune your looking at around 3 cu ft of port
And interior dim is 5.935cuft. all ports need to stay under 36 inches in length.
Originally Posted by Low_e_Red
3cu ft of Port?!?
port would eat up about 1.5 cu ft, I accidentally doubled the port numbers
ok so how about these dimensions
30deep 26long and 17.5wide
with aeroports tuned at 34hz is that enough airspace and how would it sound
ok sorry to sound dumb but whats a subsonic filter and how do u use them
and also why 4 aeroports
go to this link this guy has made me a desgin what do you think of it
http://www.caraudio.com/forum/showth...=282680&page=3
also one more question the lower the tuning the louder or is it the opposite
also whats the difference in normal port and aeroports pros and cons of both
ok so go with 4 4 inch or what
do you build boxes or kno somone who would build me the best box for me
and also whats the difference in normal port and aeroports
and subsonic filter is on the amp correct how do i use that
