Mounting Amp
Old Dec 10, 2007 | 11:49 AM
watoola's Avatar
Mounting Amp
I have an amp/sub combo that has mounting brackets and i would like to mount it in the middle under my back seat (supercrew). i measured and it fits. can i just drill through the floor?
Old Dec 10, 2007 | 01:39 PM
cgndhhh's Avatar
if u want to mount it under the back seat u can get away with just gettin some 3/4", 1" screws and screwing on top of the carpet, the carpet and carpet padding will actually hold the amp enough so it won't be moving around much. U could also mount them against the wall behind the backseat. if you search there are lost of people that have dones it this way
Old Dec 10, 2007 | 03:06 PM
Low_e_Red's Avatar
Look three times. Drill once. As long as you arent hitting anything it is all good.
Old Dec 10, 2007 | 06:08 PM
Bartak1's Avatar
Originally Posted by Low_e_Red
Look three times. Drill once. As long as you are hitting anything it is all good.
x a billion.
Not a bad idea to put some silicone or undercoating or the like on the bottom side from under the truck...because if you drill a screw through and just leave it, you WILL get water in there.
If you didnt want to drill through the floor Im sure there would be a way to mount a piece of MDF or something to the center bracket for the seat then mount the amp to that too.
Whatever works for you.
