Build your own.
Old Oct 16, 2007 | 06:59 PM
Jolly_Green_Giant's Avatar
Thumbs up Build your own.
I know it's rough but I don't have a cad program or proper drafting tools.
These measurments are exterior dimentions only so you can adapt the thickness of your material as needed. Also in inches of course.
For this to fit you will need to do at least the washer lift on the front of the box. The support on the front corner would work better if increased to 2" as well.
For 04 - 07 Supercrew
enjoy!
Old Oct 16, 2007 | 07:56 PM
bah! left off one. Front is 9 1/4" at the driver's side corner and 6 1/4" at the passenger side corner.
Old Oct 16, 2007 | 10:54 PM
mSaLL150's Avatar
is the front 9 1/4" including the corner support bracket?
(btw thanks for the diagram, i think im going with 2 IDQ v.3s and might use this to help design my own box.)
you did fit a 5.75" deep sub right? cuz thats how deep the v.3s are...
Old Oct 16, 2007 | 11:15 PM
Yes, it does
Yes I did. I had to dremel 1/2" out behind the magnet. However, I didn't have to go all the way through the board.
Very very happy with the sound of the box btw.
Old Oct 17, 2007 | 12:17 AM
mSaLL150's Avatar
did you use 3/4" or 5/8" MDF?
Old Oct 17, 2007 | 02:27 AM
GA FOO 88's Avatar
If you have depth issues around 1/2 inch or so of fitting, cut a circle out a little bigger than the magnet on the back of the box and fiberglass over the cut out.
Old Oct 17, 2007 | 07:12 AM
MGDfan's Avatar
To JGG - you are a treasure!
Thanks!
MGD
Old Oct 17, 2007 | 07:41 AM
I used 3/4"
Why put in a big extra hole, an unstable butt joint, and add to the depth of the box no matter how thin you glass when It's plenty solid as is and is seamless. silly wabbit.
Old Oct 17, 2007 | 02:17 PM
Devildog101's Avatar
Thanks for the dimensions. We were waiting on those. I plan on doing a single sub/2 amp rack all under the back seat, and all one piece.
Wish me luck...
And thanks again Giant!
