Help!!
Old Sep 3, 2007 | 08:34 PM
Drdudsads
Guest
Posts: n/a
Help!!
333
Old Sep 3, 2007 | 09:18 PM
Bartak1's Avatar
How much airspace do they require???
Also, are you planning on running one, or a pair of them?
What year and cab configuration is your truck?
Old Sep 3, 2007 | 09:22 PM
Drdudsads
Guest
Posts: n/a
333
Old Sep 3, 2007 | 09:30 PM
mSaLL150's Avatar
hmm almost 6" depth, its going to be a tight fit. try www.supercrewsound.com you can get boxes with extended depth. it'll be just slightly under the recommended airspace but as long as your close they should sound fine.
or you could just build one.
Old Sep 3, 2007 | 09:33 PM
Drdudsads
Guest
Posts: n/a
333
Old Sep 3, 2007 | 09:47 PM
mSaLL150's Avatar
Originally Posted by Desert Racer
So then they should work and perform like they are supposed to? I would much rather buy a box then build it. I am not good at building sub boxes.
as long as they fit in the box and theres at least 3/4" between the back of your sub and the back of the box, it should work fine.
Old Sep 3, 2007 | 09:50 PM
Drdudsads
Guest
Posts: n/a
333
