bazooka install question
I have never tinkered with wiring on my own really. I was wanting a quick, inexpensive way to beef up my sound, and I remembered the bazooka tubes when I saw that my friend had put one in the back of his car and told me that the amp was already installed into the tube. I was thinking of getting a 10 like he has. I've got an '03 extended cab (4doors) with the stock 6-cd changer. Is it possible to wire a tube straight up to the stock unit or do I need to get an aftermarket one? My buddy knows wiring and can help me to get it done if it is possible.
thanks
thanks
If the Bazooka tube has Speaker level/high level inputs, then yes you can wire one up to the stock unit.
Just tap into the speaker wires and run wire from there to the speaker/high level inputs.
If it only has low level inputs (RCA type connection) you will need to get a Line Out Convertor.
Where would you be putting this? I got the BTA10200 (10" 200W RMS) for my wife's Accord, but then again she has a trunk.
It will work and sound good - but it will probably have to sit out in the open and get in the way.
