Bazooka Tube: How to install?
I was recently given a 8 inch bazooka bass tube. It has the amp inside the tube. I was wondering if anyone knew how this hooks up to my system. Any advice will help! thanks!
see if your existing amp has any pass thru outputs for connecting to another amp, if it does then you can run a short RCA from that amp to the bazooka tube, your other option is to run another long RCA from your sony headunit to the bazooka tube. You need to use a distribution block inline with your power cable for your existing amp. a distro block will split the main power cable into 2 or more smaller cables for hooking to multiple amps. and then just use a jumper to jump your remote lead from the existing amp to the bazooka tube amp
