How does this setup look????
Old Jun 19, 2007 | 11:02 AM
TRUEBLUE2004's Avatar
I was just wondering what you all think about this set up. Anything you would change. Anything else I would need besides the RCA cables and box. Thinking of using the musicmoose box w/ spacer kit.
Contents of Shopping Cart
Item to Purchase Qty. Price after Options Ext. Price Remove
KDC-X591 - Kenwood Excelon USB/AAC/WMA/MP3/WAV/CD Receiver with External Media Control
Item#: 76430 $169.99 $169.99
SPR-57LP - Alpine 5 x 7" Type-R Coaxial 2-Way Speakers
Item#: 73456 $104.99 $104.99
SPR-57LS - Alpine 5" x7" Type-R Component 2-Way Speaker
Item#: 73458 $149.99 $149.99
16-MCH600 - Memphis Belle-600 Watts total power MClass Series Amplifier
Item#: 73623 $484.99 $484.99
10W3 V2 D2 - JL Audio 10" DVC Subwoofer
Item#: 10W3 V2 $159.99 $159.99
SWK4 - Stinger 4 Gauge Power Wiring Kit
Item#: 76417 $79.99 $79.99
Subtotal: $1,149.94
Coupon: (Enter and recalculate to apply)
Thanks for any suggestions.
Btw the amp will be run at 55x4 and 200x1 2ohm or 400x1 1ohm
Old Jun 19, 2007 | 11:13 AM
dconder's Avatar
Subtotal: $1,149.94
I like everything except the 5 x 7 components. I would go with 5 1/4" or even better 6 1/2" before I would use the 5 x 7. I have never been a fan of the 5 x 7 shape. 6 1/2" would provide better lows up front. Other than that, looks pretty good.
Old Jun 19, 2007 | 11:28 AM
styxnpicks's Avatar
looks like a rip off
Old Jun 19, 2007 | 11:31 AM
What looks like a rip off?
Old Jun 19, 2007 | 11:35 AM
styxnpicks's Avatar
the whole thing, you can get better for cheaper
Old Jun 19, 2007 | 11:43 AM
Can you please elaborate some. Looking for a good quality sound. Don't have to be the loudest.
Man I thought I had researched this alot.
Old Jun 19, 2007 | 11:51 AM
styxnpicks's Avatar
5x7's are not going to give you quality sound
rear fill is not going to give you quality sound
alpine hype-R speakers are not worth what you would pay for them and will not give you quality sound
the kenwood HU is good, those are quality units, shame you cant spring a little more for nice double Di, JL make decent subs
you need to rethink your front stage and ditch the rear stage
Old Jun 19, 2007 | 02:16 PM
What do you recomend for a front stage then. I checked the amp specs it can be bridged to 150x2. If I do that would I need to get 2 subs instead of 1 to equal out the sound of the highs and lows.
Sorry for all the ???'s. Been out of the audio system scene since 1994.
Old Jun 19, 2007 | 02:22 PM
dconder's Avatar
You would still be alright with only one sub. Bridging and running 150 x 2 to the front comps would be great. You can run the rear speakers off the head units power or not at all. Depending on your budget, I would look at Rainbow. They have great comp sets from $200 to $1k. For the money, they are hard to beat at their price point.
Old Jun 19, 2007 | 03:29 PM
Man You said rainbows and I was like noway am I paying over $1000 for a set of componets I don't care how good they sound. But after some checking I found 2 lines that look doable. The CMX-265 and the SLC-265. Which one would be the better of the two. What will I have to do to install them. Where can I get them from other than premier audio.
Old Jun 19, 2007 | 07:59 PM
Dallasstars10's Avatar
You will love the headunit!!
Old Jun 21, 2007 | 04:09 PM
well I had a change of mind on that. I have a alpine cda-9856 head unit now. Man I work with is trading in his mercury mariner and sold me the head unit, i-pod control, and xm adapter for $125.
BTW does anybody know if the plug for the mariner and the f 150 are the same. I measured and the face plate is different. My local car shop only sells harnesses with installs only and they said it's different but I want to be sure.
Old Jun 21, 2007 | 08:12 PM
Impact9's Avatar
Can't say for certain but I'd be willing to bet they are not the same. Just but a metra install kit off ebay for $12 they come with adapters. I looked one up last night.
Far as the type R's I've been running a type R 6.5 for a center channel and for it's low power it sounds pretty good in the dash. I got them on ebay for like $30 so well worth it.
Old Jun 25, 2007 | 09:53 AM
Well I might have made a mistake but anyway here's what I got this weekend.
Front door Memphis 6 1/2 componets
Rear door Memphis 5x7 coaxials w/ crossover
4 channel amp Rockford Fosgate 60x4 rms
Sub amp Rockford Fosgate 350x1 rms @ 2ohm.
Sub Undecided. Kicker cvr10/IDQ v.2 maybe
Sub box Music moose???
Old Jun 25, 2007 | 10:00 AM
dconder's Avatar
Looks good. I would for sure take the IDQ over the CVR anyday. Worlds of SQ difference between the two. IDQ's are some of the best SQ subs around. Dual 4 ohm voice coil IDQ in a small sealed box and you have great low end punch.
