Got a few questions
Got a few questions
My friend has 2 12" Eclipse aluminum coned subs with an amp that I want to buy but installation is something id do by myself. Is it hard to hook up the subs and the amp to my car? everything is stock in my 2002 supercrew and I'm new to audio. Any help will be greatly appreciated
If the amp can be connected through the speaker leads then you can connect it to your stock HU, otherwise you will either need to install an adapter that will allow you to run RCA cables to the amp or you will have to replace the stock unit with something aftermarket.
Originally Posted by Flan
Id by a 2x12 sub box for under the rear seats in back
good luck getting them sumbishes to fit under the seat, It took me 2 weeks, and I still have to have the seats folded up to play music
