How do I replace stock tweeter 2006
Old May 10, 2007 | 01:37 PM
WaWaTuSi's Avatar
I pulled the grill off an see the tweeter in there. How is it bolted in and how do I get it out?
2006 scab.
Thanks!
Old May 10, 2007 | 01:44 PM
TBDAugs's Avatar
I believe they are attached via the rear of the door trim. To replace you need to remove your door trim so you can access the back of the tweeter.
Caveat, since I didn't have the tweeter installed I'm not for sure, but this is one of the more OEM connection methods for tweets, and it's how I installed my tweets.
MBQAugs
Old May 10, 2007 | 01:53 PM
Impact9's Avatar
you have to remove the door panel. If you look behind the speaker grill you will see 4 screws holding the speaker in, of course you know that, but for the sake of future search bear with me. Anyways remove the speaker and those plastic things the screw go into. You can yank them out with needle nose pliers. This will make taking the panel off a lot easier.
Now behind the door handle is a little panel you need to take off using a flat tip. Behind there are 2- 5/8" bolts that you need to remove,
Then take a flat tip and pop the window switch panel off the arm rest. Remove the connectors going to the switches. Then behind in the arm rest is 1- 10mm bolt, take that out.
Along the bottom of the door panel are 2- 6mm screws, remove those.
Then you need to grab the arm rest and lift the panel straight up NOT out. Once is raises about an inch pull it out.
The door release handle will need to be popped loose from the door panel. Take a flat tip and gently release the latch holding it in.
Now you should be able to get to everything inside just fine and reverse to install. That means the door handle goes back in first, then remount the panel, ect., ect.
Old May 10, 2007 | 02:23 PM
WaWaTuSi's Avatar
Thanks! :tu:
Old May 12, 2007 | 10:19 PM
MOJO5.4's Avatar
WaWaTuSi are you gonna sell the factory tweeters? If so, how much? I am interested in purchasing a set of factory F150 tweeters. Let me know....thanks
