Rainbow Q's
Old May 13, 2007 | 10:38 AM
Impact9's Avatar
Originally Posted by extremeethan
Last night I was rocking out to some pink and looked down and my tweeter light was glowing. I adjusted the EQ and got it to turn off but my question is, is it allright to have that light on or if that light is on it means turn them down. It wasnt bright like when I was first setting my gains but just glowing and would get a little bright every once in a while. I know it is the over load light but is it all right to be on tell you blow it or do you always need to make sure it if off?
Back to the original question I just noticed something interesting with my Germ crossovers. I finally got some quality time tuning my system with a Velman O-scope to make sure that I wasn't clipping signals which we all should know can make a system sound like crap. I knew I was clipping pretty badly and the O-scope showed a nasty signal coming out of the amp because I had the gains set way too high. Now this seems to be why the lights are flashing on the crossover. When I got the clipping fixed the lights on the crossover stopped completly.
If you understand that, cool, otherwise keep reading:
Ok let me further explain my theory....
I had 100w going to my germs. I was told these things really perform best with closer to 300w. So tonights I was game but I had to be safe and check the clipping. My headunit, by my surprise, will go max volume and have no, zero, zippo, zilch for clipping. I was tossing all manner of test tones at it and nothing would clip. Now that is damned impressive to me.
Ok so I went to the amp and checked the output on the bridged setup with various mid range test tones adjusting the gains down to a perfect sine wave. I hooked the germs back up this time with 450w RMS coming at them. Again the light bulb never so much as glowed. Everything is working great. I have no ideal how or why yet but that little bulb seems to be protecting the speakers from nasty signals somehow.
If your curious the Germs were singing like nothing I have ever heard! 450w don't even phase these things. OMG you all were not kidding about how these things perform! Oh and Styx I don't miss my rear fill in the least.
Old May 13, 2007 | 09:19 PM
extremeethan's Avatar
Ive been told by a few people that kenwood set their internal gains low from the factory so that they dont clip at any volume and then I looked down and you are running a kenwood HU so that must be true, I tend not to believe joe shmo. Also Ill have to get my amp on a scope soon and get it all adjusted right I set my gains by the 3/4 volume thing and this much AC volts out the wire type crap. Now I only need to find someone with a scope to do it with........
Old May 13, 2007 | 10:31 PM
Impact9's Avatar
If you can spare about $100 look on ebay for a Velleman HPS10. Extremely easy to use.
Old May 13, 2007 | 11:05 PM
I didnt know they were that cheap! Ill ask my stereo shop if they have one if not I might look into getting that. They only problem is I have never used one before i mean I know about them and stuff but never used on, are they easy to use?
Old May 14, 2007 | 04:32 AM
Impact9's Avatar
yea really easy. If you get one i can walk you through the use.
