Finally...... A video........
Originally Posted by jmt0645
if you want 2 10's, for sound quality IDQ's like mine. For pure *bump*, I'd go with ROCKFORDFOSGATE or KICKER.
Originally Posted by Speedy8
the Rockford fosgate are low on prices, are they good, cause im one of those get what you pay for type believer
I'd look into 2 Punch series 10's at stage 2 level. That should satisfy your needs very well.
Rockford is very reputable, Customer service is top notch to boot
I'll most likely get those
Also should i get a 1000/1 amp?
Thanks man, thats taken alot of work off from me... I was looking and tryin to get the best bang for the buck, and of course get the sound i want.. But i found someone who uses the same stuff for the same reason.. Thanks man
1) Rockford Punch series P600.1BD
2) Zapco DC Reference series 500.2 (hard to find though)
3)Hifonics Zues series ZXi 6006
You can find all of them at www.woofersetc.com
I would reccomend 3 amps.
but be aware this site is not an authorized Zapco dealer even though they sell Zapco products. They are authorized for everything else though.
and are you talking about these subs?
http://www.woofersetc.com/index.cfm?...roduct_ID=4486
Originally Posted by Jwool15
Zapco is superior to all other amplifiers made
edit: and if i were to get the Zapco and decided to 'upgrade' my subs, is it powerful enough to handle most subs?
thanks, but I wasn't going for SPL, I was going for SQ with this system. My next system will be SPL/SQ. Best of both worlds.
Even with SQ you'll want to use Pink Noise to dial in the system. Pink Noise is used with an RTA to see a full spectrum of frequencies. The output looks like a graphic EQ in real time which you can adjust peaks in valleys in frequencies bumps. Pink noise covers the full spectrum of sound 20mhz to 20khz and not just certain frequencies at certain times like music represents. Judging by your video I would say you have some pretty large spikes in the 200Mhz and below range. LOL. Definitely not a SQ thing but an SPL thing.
Originally Posted by mtordie
If you were going for SQ then the SPL meter wasn't needed for the video! LOL
I used the meter so you could judge how loud it was for an SQ setup.
if you dont mind me askin... how much and where did you get it? I used to have one that registered up to 150dB that plugged into the 12v plug but like i said... it was capped at 150 so if this does up to 180 it might be a decent cheap alternative to a TermLab
edit: - oh and does it have a function that will hold the peak dB instead of just real time dB readings like in ur vid?
